HELP NEED QUICK REPLY
Solved by GlassBomb,
2 minutes ago, wadzftw said:IS IT WORTH IT TO SPEND 180 MORE ON A Z97 AND 4690K OR JUST GO FOR A H81 P33 AND 4460?
The 4460 and H81 will be a much better value overall. That $180 can easily spent on other parts of the computer. SSD, Monitor, peripherals, etc.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
