My specs are Intel Core i5 4460, Cooler Master HAF X Case, Adata 128GB SSD, Cooler Master M2 Silent Pro 850 Watt, Cosair Vengeance DDR3 2X4GB RAM and an Asrock Z97 Anniversary Motherboard. I've connected my TV and my PC through HDMI, and it won't turn on at all. I've tired it without the HDMI and it still won't turn on. Maybe you guys can figure out my problem?
https://linustechtips.com/topic/539428-power-issue/
what wont turn on
the TV or the PC
https://linustechtips.com/topic/539428-power-issue/#findComment-7146227
1 minute ago, AndyT27 said:
The PC won't turn on.
are all the cables plugged in and the PSU in the on position.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/539428-power-issue/#findComment-7146248
Just now, AndyT27 said:
Yes, they're all connected
is the switch on the back of the PSU on
https://linustechtips.com/topic/539428-power-issue/#findComment-7146253
Yes
do you have a way to plug in a fan to your PSU?
https://linustechtips.com/topic/539428-power-issue/#findComment-7146271
What do you mean? Like a cooling fan or?
yes a cooling fan.
https://linustechtips.com/topic/539428-power-issue/#findComment-7146281
2 minutes ago, thatguyyouknow75 said:
Double check everything is plugged in and that the psu switch is on, then reseat ram gpu and power connectors. Finally start trying to isolate the issue by testing components individually
Okay, so should I test the RAM first because I don't think it's my CPU since that's brand new.
https://linustechtips.com/topic/539428-power-issue/#findComment-7146282
The only reason I think it's not the flu is because if it goes in wrong it breaks. It can't hurt to reinstall and check that no pins are bent
https://linustechtips.com/topic/539428-power-issue/#findComment-7146306
Could just be the motherboard just crapping out on you
https://linustechtips.com/topic/539428-power-issue/#findComment-7146715
You can try taking it all out of your case and testing open-air, to make sure your motherboard isn't shorting stuff.
.Also, you did install motherboard standoffs, right?
Core i5 6600k | Gigabyte GTX 970 Windforce | MSI Z170 Krait Gaming Crucial Ballistix Sport 16GB DDR4 2400 | NZXT S340 Red                                              EVGA SuperNOVA 750 G2 | Coolermaster Hyper 212 Evo | Razer Blackwidow Tournament | Logitech G600 Razer Kraken USB        If you want me to see your post, please remember to quote me!
https://linustechtips.com/topic/539428-power-issue/#findComment-7147113
