Problems with paste and lagg when edit.
Solved by colonel_mortis,
3 minutes ago, L0gic said:For example, on the share your setup post i wanted to paste my imgur link. I only copied/pasted the url.
For example, if i wished it to be here
then it would appear down here, not being able to remove the space between.
I am currently not able to re-produce the bug, so it might be gone by now.
If you're not able to reproduce it, it sounds like you probably managed to copy too much last time. You would have the same issue on any site.
