MINI ITX or ATX?
16 members have voted
  1. 1. MINI ITX or ATX?
    • Mini ITX
      4
    • ATX
      12
Mini ITX is much more portable as it is smaller and looks pretty nice if done right (IMO) but they tend to be more expensive for these reasons and they also lack features such as less PCI / PCIe Slots as well as lacking some I/O ports.
ATX builds are obviously much larger and they tend to be cheaper, they're not portable but at the same time they are much more spacious allowing them to offer many more ports and PCI / PCIe slots.
https://linustechtips.com/topic/538444-mini-itx-or-atx/#findComment-7136768
ATX has more expandability, while ITX is more compact. ATX usually has better VRM and less compromises(like better audio), but boards like the Asus Impact exist, so it really biols down to what you want and your goal with your PC.
https://linustechtips.com/topic/538444-mini-itx-or-atx/#findComment-7136776
ATX is probably more preferable to most gamers. It generally has more expandibility, can reach better temps since the heat producing parts are further apart (allows better cooling) just at the expense of size.
My ~$200 USD build:
AMD A8-7600    G. Skill Ripjaws Z @1800 CAS 8     EVGA 500w 80+ PSU    Gigabyte GAF2A68HM-DS2H Motherboard
https://linustechtips.com/topic/538444-mini-itx-or-atx/#findComment-7136791
atx has more features, that could be handy.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/538444-mini-itx-or-atx/#findComment-7136827
why such extremes?  I wish I had built m-atx.  Gives you reasonable room for expansion while not being oversized.  I've got no problem with my atx though, actually currently using e-atx (not full e-atx, just an inch or so bigger
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/538444-mini-itx-or-atx/#findComment-7136929
What do you mean by extremes?
https://linustechtips.com/topic/538444-mini-itx-or-atx/#findComment-7137280
I like M-ATX because it has everything I need. i don't do sli so i like only having 4 pcie slots.
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
https://linustechtips.com/topic/538444-mini-itx-or-atx/#findComment-7137314
I just meant either the smallest (mini itx) or the largest normal size (atx).   I'm just saying that m-atx is a good option, being in between the two.  They're somewhat compact, usually fully featured, can SLI/CF in the future, dont usually cost more than atx mobo
https://linustechtips.com/topic/538444-mini-itx-or-atx/#findComment-7137334
(not full e-atx, just ane
I see your point, thanks for the input.
https://linustechtips.com/topic/538444-mini-itx-or-atx/#findComment-7137393
8 minutes ago, Lonewolf7381 said:
What are the advantages of a pci-e ssd?
Faster speed, usually more expensive though.
XPS 13 9350:
i5-6200U
8GB RAM
Workstation Laptop:
i7-4720HQ
GeForce GTX 980M 4G
https://linustechtips.com/topic/538444-mini-itx-or-atx/#findComment-7137461
