So I am building a new PC and would like it if you guys could help pick the parts out for me :)
I will be using the PC for gaming mostly and for use with CAD program's for my Design work may also be doing some game building and video editing. I have a budget of around 900 pounds and don't need a monitor , OS or keyboard or mouse .
Plus no need for an ssd as I've already picked up a 250gb Samsung 840 one for 42 pounds (because amazon messed up pricing) thanks guys
Main use is still gaming I would prefer to have a better gaming PC that will gperform well I'm CAD program's
AMD FX-8350 II ASUS R9-20x DCU2 TOP II Fractal Design R4 II Samsung 840 Evo 250gb SSD II Gigabyte 990FXA UD-3 II 8GB Corsair XMS II Cooler Master Seidon 120mm II ACER H236HL Monitor II Corsair K70 II Razer Deathadder II Kinect II
Go check out my Build Log for my "Home Made Gaming POD"
http://linustechtips.com/main/topic/83872-home-made-gaming-pod-build-log/
https://linustechtips.com/topic/53815-first-build-please-help/
Fit a amd hd 7970
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722499
do your cad programs utilize cuda or opencl?
Nvidia GPU variant:
[PCPartPicker part list](http://uk.pcpartpicker.com/p/1ACNr) / [Price breakdown by merchant](http://uk.pcpartpicker.com/p/1ACNr/by_merchant/) / [benchmarks](http://uk.pcpartpicker.com/p/1ACNr/benchmarks/)
Type|Item|Price
**CPU** | [intel Xeon E3-1230 V2 3.3GHz Quad-Core Processor](http://uk.pcpartpicker.com/part/intel-cpu-bx80637e31230v2) | £180.73 @ Scan.co.uk
**Motherboard** | [Asus P8H77-V ATX LGA1155 Motherboard](http://uk.pcpartpicker.com/part/asus-motherboard-p8h77v) | £69.99 @ Ebuyer
**Memory** | [Patriot Viper 3 16GB (2 x 8GB) DDR3-1866 Memory](http://uk.pcpartpicker.com/part/patriot-memory-pv316g186c0k) | £100.61 @ Amazon UK
**Storage** | [seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive](http://uk.pcpartpicker.com/part/seagate-internal-hard-drive-st1000dm003) | £46.85 @ Aria PC
**Video Card** | [MSI GeForce GTX 770 4GB Video Card](http://uk.pcpartpicker.com/part/msi-video-card-n770tf4gd5oc) | £359.72 @ Scan.co.uk
**Case** | [Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case](http://uk.pcpartpicker.com/part/fractal-design-case-fdcadefr4bl) | £73.00 @ Amazon UK
**Power Supply** | [Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply](http://uk.pcpartpicker.com/part/corsair-power-supply-cx600m) | £57.56 @ Amazon UK
 | | **Total**
 | Prices include shipping, taxes, and discounts when available. | £888.46
 | Generated by PCPartPicker 2013-09-06 17:48 BST+0100 |
you could step up to a xeon e3-1230v3 and a h87 mb, but pcpartpicker has for what ever reason no haswell xeons listed yet.
if you need opencl instead, just pick any 7970, if you need your system soon or wait for the 9xxx series to be released in october
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722522
AutoCAD has supported OpenCL and CUDA since 2012
Here you go: http://uk.pcpartpicker.com/p/1ACVX
Is it too expensive?
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722578
Nvidia GPU variant:
Type|Item|Price
 | | **Total**
I use various CAD program's and I think they vary with Cuba and opencl
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722586
May be just abit over however even though I do use various CAD program's my main use will still be gaming and general productivity so something that is more optimised for gaming but will perform decently in those program's would be better
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722592
This would do exactly that. the 7950 is good for gaming and should max out many games.
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722600
Ok cool thanks for the help , do you think I should wait for the 9000 series to come out as I can wait till then
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722602
Oh, forgot to add it would max out many games at 1080p--don't expect much for 4K  :lol:
If you can wait, build it later. Prices will drop when the 9000 series comes out. Who knows, it might be good and not overly expensive when it first launches.
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722607
For water cooling I found this deal but wanna know what you think
http://www.scan.co.uk/products/corsair-hydro-series-h100-refurbished-extreme-performance-liquid-cpu-cooler-240mm-radiator-plus-2-fa
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722654
That's just a H100. the H100 and H100i comes with pretty crappy fans. It's often much better to replace it with better fans.
With the Kraken x60, you can just stick with stock.
I'd generally not get an H100 as well.
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722669
Ok I'm not going to be crazy overclocking when I first get it as this is my first build so need to learn what to do etc , however with this mobo it comes with a water cooler would this be adequate just for maybe a little oc then after a while I will upgrade to the cooler you have said
http://www.novatech.co.uk/products/components/motherboards/intel1150z87chipset/atxformfactor/z87-g43-bundle.html
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722688
The Hyper 212 Evo cools better than the Seidon 120M.
You'd want a cpu with a hefty overclock to render faster. Stick with a better cooler.
https://linustechtips.com/topic/53815-first-build-please-help/#findComment-722698
