is this case right for me?
HmmR
Moved to Cases and Power Supplies.
yo guys i need your help
im going to buy this case soon i want to know whether all parts will fit inside!!
this case = AKA Aerocool GT-A
GPU up to 310mm (Strix = 280mm)
max CPU cooler: 165mm (212Evo = 158mm)
so, yea @HmmR
so, yea @HmmR
thx man appreciate it
Yes, it should fit, but you might have to remove some drive bays (the website for the case is very, very vague).
They have a Specifications section for the product.
It should fit all the parts.
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
Yes, it will fit
CPU I7 8700k oc'd @ 5ghz Motherboard ASUS Z370 E RAM G.Skill Trident RGB 16gb (2x8) ddr4 3000mh GPU EVGA GTX 980ti SSC
btw, you sure you want that PSU?
that is one of the shittiest PSU's
and you have pretty high-end components
