I was just wondering what you all thought was the best mouse for shooters. I play a lot of bf3 and I snipe (or at least I try to xD) so i want something thats steady, is higher dpi better or that? I was thinking about the Razer DeathAdder. If you do suggest a mouse try and stay around 40$ usd thanks :)
Also mouse pads, would a more faster one be better?
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/5359-best-mouse-for-shooters/
"More faster"?
Higher DPI is only good if you need higher DPI. Most people are fine with less than 2k. What you're looking for is a sensor without acceleration and high perfect control/malfunction speeds, which the follow mice have...
Razer Deathadder
Razer Krait 4G
Razer Abyssus
Logitech G400
CM Storm Spawn
CM Storm Recon
Zowie AM
Zowie EC1/2 Evo
Zowie FK
Roccat Savu
Cyborg R.A.T. 3 Optical
Subjective shape/feature preferences aside, those are objectively the best mice for FPS.
As for the mouse pad, I suppose it depends whether you prefer speed or control.
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-61316
I would get the Corsair M65 because it has no acceleration.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-61340
I thought higher dpi meant the mouse was more accurate.
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-61341
Yep just anything with a good sensor that tracks well and has no acceleration/angle snapping etc. DPI is more of a marketing thing. One of the best Quake players in the world uses a 400 dpi Microsoft WMO with Steelseries sticker on it to keep the sponsors happy. Steelseries Qck is a pretty standard choice for mousepads.
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-61344
so its the m60 that doesn't have acceleration? getting these two models mixed up i think...
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-61813
They both have acceleration. The A9800 is based off the A9500, which is what was in the M60s. Any laser sensor will have acceleration, apart for the Phillips Twin-Eye which has it's own issues. Optical mice are the best with shooters for now.
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-61843
I would personally go for something a little more heavy or has customizable weights on the mice as it gives you good control of the mouse especially when sniping. I currently use a sensei which is very customizable software wise. Not so much in physical customization however. :)
Across the vast and majestic gulf of time and space, the jimmies rustle softly.
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-62376
ok Thanks for clarifying! Not really an expert in mouses...
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-62434
I have thouht about those types but I'm really not sure if I want a heavy mouse. I'm using a 5$ dollar usb mouse xD i like that its light weight but I haven't used a heavy mouse so I'm not sure >.>
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-62982
Deathadder! After razer sorted out it's synapse issues the mouse is really accurate and customisable.
Yea didn't you have to be online for the mouse macros to work? (Fixed now)
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-62986
Weight is up to the user. I know I already mentioned it, but the Microsoft Wheel Mouse Optical/1.1a might be a good option if you want something lighter. I switched back after using a MX518 and I love the lighter weight. Check your local thrift store every now and again and keep an eye out for one. They are relatively common. I was able to build up my stash of 4 in about a week and they only cost 3-4 bucks.
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-63370
Alrighty, I will :) thanks
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-63986
I play plenty of fps and tps, aswell as mmorpg, rts etc... pretty much every genre and my 15 dollar zalman mouse works great. It's well built (rage smashed once or twice :/) and I haven't had no issues with it. Here is a link for it if you're thinking about using. I've used it for over a year now and it looks and works like it was new, I can see this mouse easily lasting me a couple of years. http://www.newegg.com/Product/Product.aspx?Item=N82E16826501010
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-65294
I love using my DeathAdder for FPS gaming.
The buttons on the side are excellent for binding knife, or nades, depending on what your playing.
Also the custom sensitivity for X and Y axis is handy in some games. and overall for my needs, the mouse has a fast polling rate.
while (true) {
    live();
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-66459
I was thinking of using the buttons for grenades and defib in bf3 :)
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-67407
"More faster"? Higher DPI is only good if you need higher DPI. Most people are fine with less than 2k. What you're looking for is a sensor without acceleration and high perfect control/malfunction speeds' date=' which the follow mice have... Razer Deathadder Razer Krait 4G Razer Abyssus Logitech G400 CM Storm Spawn CM Storm Recon Zowie AM Zowie EC1/2 Evo Zowie FK Roccat Savu Cyborg R.A.T. 3 Optical Subjective shape/feature preferences aside, those are objectively the best mice for FPS. As for the mouse pad, I suppose it depends whether you prefer speed or control.[/quote']
I totally agree with Toby's advice. These are all worthwhile mice for FPS
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-69290
You can disable mouse acceleration on all mice so don't worry about that. I would find a mouse from a trusted manufacturer that you like the feel of and has the functions you need.
I use the SteelSeries Diablo mouse which fits my needs well and feels great.
Generally you want a lower dpi or cpi when playing fps games as the give better accuracy but you also need quite a large surface to move the mouse on.
With regards to mouse mats/pads I would say go with cloth, I'm.currently using the XFX Warpad and it works a charm and the weave is tight and accurate.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-69333
I use a Logitech G700 for everything and it's great. A Logitech G9x is more in your price range and is also a very nice mouse. Good thing about the G700 is I use buttons on the side for push to talk and throw grenades etc. Mines going 2 years strong now with no problems. Mouse pad wise definitely a Razer exact mat. I personally despise cloth mats because of how disgusting they get after a bit of use and how much better it feels to track on a solid surface. You have to get exact mats second hand now, as they no long manufacture them.
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-69400
That is misinformation. What you're thinking of is software-side mouse acceleration, which can be turned off, but there is still acceleration inherent in most mouse sensors, which can not be avoided.
https://linustechtips.com/topic/5359-best-mouse-for-shooters/#findComment-69530
