Hi guys
I am studying for a maths test and I cant figure out one example...
So we need to calculate the angle between two vectors, S and T
I did few examples and I got the answers right except one of them and I just CANT figure out what am I doing wrong with this example
could you please point it out for me?
So the dot product is:
9 * (-2) + 12 * 6 + 18 * 7 = 180
And then:
|T| = sqrt(9+ 12+ 182)
|T| = sqrt(549)
|T| = 23.43
so far so good.
|S| = sqrt(-2+ 6+ 72)
|S| = sqrt(81)
|S| = 9
|S| * |T| = 23.43 * 9 = 210.87
so we end up with
θ = cos-1(180 / 210.87)
When I tap that into the calculator it gives the answer 31.39°
The answer in the answer sheet is 35.48° and it is also the same when I tap in this question into WolframAlpha.
Something is clearly wrong with my workings but it seems like it's only happening when negative numbers are involved, since I can do other examples just fine and I get the right answer...
Please help!!!
https://linustechtips.com/topic/535356-maths-problem-with-vectors/
http://www.wolframalpha.com/
there you go, go there
Builds:
Would be awesome if you'd at least read the entire post
i did my best to help, im not that good with this stuff and Wolfram Alpha usiually has the answers, missed the part about that you had put it there but i think it probably comes down to how many decimals were used if it was shortened otherwise i have no idea
Builds:
-2^2 + 6^2 + 7^2 is not 81. It's 89.
Anything squared is positive. So -2^2 is 4, not -4
acos (180/(sqrt(89) x23.43)) is your answer
I just checked and for some reason my calculator says that -2= -4.
What the hell  :o
Thank you very much for pointing this out, I don't know how did I miss that...
I think I got the answer already, it was the calculator playing tricks on me...
You have to put -2 in parenthesis.
(-2)^2 is 4, but the calculator sees -2^2 as (-1) x 2^2 = -4. It's a rule of thumb in calculus and pre-calculus that anything squared is positive.
I just blindly believed my calculator like a sheep and didn't even notice that squaring a negative gave a negative number, lol
What the hell  :o
It could be how you typed it in. (see above)
When you're finding the magnitude of the vectors, leave them in exact form. Now plug this into to your calculator.
EDIT: Someone already caught your mistake. Use parentheses, always.
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
baaaaaaaaaaaaaaa
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
acos (180/(sqrt(89) x23.43)) is your answer = 35.47779 ~ 35.48 degrees
baaaaaaaaaaaaaaa
Hey guys I just wanted to say that I managed to pass the test today. Thank you all for help :D!
did you get any grade, or did you just 'pass'
I did vectors last semester, but it looked quite different, for two unknowns we solved it with a simultaneous equation. So maybe look that up. :)
EDIT; never mind, you seem to be doing it a different way :3
Bleigh!  Ever hear of AC series?
I got 60% which is Okay but not great, not too horrible either though.
The pass threshold is 40%
wow.. that is terrible
my condolences
my condolences
I'm just glad I passed so I don't have to resit it.
I didn't know that we had a test coming and I studied literally on the very last day for it and I was panicking that I'll fail it.
I got 92% for my first test though so my average is still decent-ish fr this module :P
My average right now is 76% so I'm still getting the best grade for this module (75%+) if I keep it until the end of the term :D
My dad would kill me if I got that grade...
