No sound and other Windows problems
Solved by Webnerdz,
I had the problem with the windows key and search bar not working when i first installed windows 10, I googled it and found a solution, it was a windows powershell command in cmd but i can't remember the website, google it and it might pop up. Hope this helped in some way.
Featured Topics
Od1sseas ·
Posted in Operating Systems1 -
amaliasugar ·
Posted in Graphics Cards0 -
2
Louscou ·
Posted in Troubleshooting2 -
1
nulcow ·
Posted in Laptops and Pre-Built Systems2 -
2
1
SteffanF ·
Posted in New Builds and Planning3 -
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
