There was something a while back talking about newer uTorrent versions having a bitcoin miner program along with it, I cant remember what it was called. The stupid miner does nothing to benefit the end user, instead, any coins your machine mines, it sends to the company that owns the program, which is a charity organization.
Desktop  - AMD Phenom II X4 955 - 12gb Hyper X DDR3 - NZXT Tempest - Asus M4A78DTX EVO - Gigabyte GTX 1050 Ti - 160gb Toshiba garbage - 1tb WD garbage
Laptop - HP Pavilion G7-2269wm - AMD A8-4500M - 6gb DDR3 - 320 gig Western Digital Scorpio drive - AMD HD 7640G graphics - 17.3 inch display
Server - x2 Xeon f41 2.80GHz - 4gb DDR ECC Reg - Intel Serverboard SE7320GP2 - ATI Rage 128 8mb - 120gb Seagate boot - 640 gb Network share
you probably have a virus/malware
Is their any way for me to remove it?
What do you mean by that the only reason i installed it was for music?
out of all the torrent clients, utorrent is the one that caused the most negative news stories.
from porn ads to bitcoin miners to straight up spyware, it seems like the devs have no morals what so ever.
find the program, stop the process in task manager, and then remove the file in program files
*the company that bought them
well, its the devs that put it in there...
that said, i generally mean the company behind the software "the devs" since it takes an entire company to make a program, not just a programmer.
Well i ran malwarebytes and then lost internet after the scan and had to uninstall it and restart my PC. Uttorent is still in their using my internet
fresh install time..
Could not find anything in my program files that looked fishy.
then it probably didnt get put on your machine.
Has no one here considered that the application just hasn't been refreshed, in terms of what it is capturing?
Assuming uTorrent used quite a bit of bandwidth, it may still be showing there for whatever the time period that application has, until something else surpasses it, or it refreshes for a new cycle.
