Will the Hyper 212 Evo fit inside my Corsair 100R?
  • CPU: E3-1241v3|| MOBO: Asus B85M-G R 2.0|| RAM: Crucial Ballistix Sport (4x4) 16GB || GPU: MSI Geforce GTX 970 Gaming || CASE: Corsair 100R Carbide Series || Crucial MX100 250GB SSD + WD Blue 1TB || PSU: Sentey 750W Semi-Modular 80+ Bronze || Cooling: x2 Corsair AF120 Red LED Silent Edition
https://linustechtips.com/topic/533489-cpu-cooler/
from looking at the product pages it doesnt look like it will
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/533489-cpu-cooler/#findComment-7079806
The fan is 159.9 mm high the case is 200mm wide, allowing for the cpu the motherboard the tray the cable management gap and the case walls it would be super tight if it fits at all, I have this case and I would measure it for you but I can't find a ruler
CPU 7800x3d Motherboard Gigabyte B650 Gaming X AX RAM 64gb 2 sets Corsair Vengeance RGB Black 2x16gb 6000MHz DDR5 GPU RTX 3090 FE
https://linustechtips.com/topic/533489-cpu-cooler/#findComment-7080608
