Hello, sorry if this is a noob question but I am new to networking. So at my house I am supposed to be getting 6MBps . When I do a speed test on any site I get 7MBps. BUT when I try to download anything I get 900KBps to 1 MBps. Same for my business. At work I am getting 30 MBps when I do speedtest but am only getting 2 to 3 MBps when I download stuff. Could somebody please explain this to me/how to fix this?
Thanks.
https://linustechtips.com/topic/533412-internet-speed/
Your speed from Speedtest.net and your ISP is quoted in Mbps (Megabits per second). Download speeds are quoted in MB/s (Megabytes a second). 7Mbps = 0.875 MB/s
EDIT: There are 8 Megabits in a Megabyte. The speeds you see are correct, it's just easy to mix up/not know the differences in units. If it has a lower case "b" like "Mb", it is Megabits, whereas an upper case "B" like "MB" is Megabytes.
https://linustechtips.com/topic/533412-internet-speed/#findComment-7078968
ISP's don't measure bytes they measure bits which as stated above are 1/8 the size
@noahsheldon81 follow your post if you want notifications  ;)
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/533412-internet-speed/#findComment-7078978
Couldn't have said it better.
My ~$200 USD build:
AMD A8-7600    G. Skill Ripjaws Z @1800 CAS 8     EVGA 500w 80+ PSU    Gigabyte GAF2A68HM-DS2H Motherboard
https://linustechtips.com/topic/533412-internet-speed/#findComment-7079033
ISPs are known to detect when you are running a speedtest and give more bandwidth. I'm guessing the M vs m is a mistake. If you have a vpn try connecting to that especially if certain content is slowed. This will not allow the isp to inspect the packet. I get around 50mbps no vpn and over 100 with.
https://linustechtips.com/topic/533412-internet-speed/#findComment-7080191
That's not the issue. His speeds are correct, it's just a difference in units when measuring speed and downloads.
https://linustechtips.com/topic/533412-internet-speed/#findComment-7081345
The unit really doesn't matter, as he uses the same unit of measure(bytes) for all numbers. He's asking why he gets one speed via a test and another in a real life application of speed which is attributed to one a few things
1 your isp detects speed tests and gives full band with but not when using "normal" internet
2 the upstream server is delivering only that speed (could be Your only using 1 source to determine "real" speed)
3 his isp is engaging I'm traffic shaping which the Vpn would solve
4 the measured speed test is simply the Isp burst speed, which you can determine by doing a sustained speed test to determine
https://linustechtips.com/topic/533412-internet-speed/#findComment-7082295
He's not getting different speeds, though.
7Mbps = 900KB/s (roughly), so that download is fine.
30Mbps = 3.75MB/s. When you account for performance overhead, other users and such, 3MB/s is about right. The difference between MiB and MB, depending on the OS, could also be factored in.
He is using the same units, but most likely incorrectly. Unless he has a 240Mbps connection at work and is converting it to MB/s for some reason.
EDIT: He even states that he is new to networking. I wouldn't expect him to notice the difference between Mb/s and MB/s. There are plenty of experienced people who don't recognise it.
@noahsheldon81 could you clarify for us if you're converting from Mbps to MB/s for the speedtest and ISP quoted speed?
https://linustechtips.com/topic/533412-internet-speed/#findComment-7082325
