When I try to edit the files on my C: Drive I end up getting a message saying that I do not have permission. I am the only account and an admin.
I see how to change each file so I can but I want a permanent solution. How can I make it so I do not have to individually change each file forever.
Intel i5 4760k - Gigabyte GTX 970 - Samsung EVO SSD
Moto 360 2 Smartwatch - Macbook Air 13 Inch - Samsung Galaxy Note Edge - Senheiser Momentum Heaphones
https://linustechtips.com/topic/532613-can-not-edit-c-drive/
Delete system 32 .
Just kidding Don't do that !
You should modify your admin rights in the settings.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/532613-can-not-edit-c-drive/#findComment-7069498
Delete system 32 .
I deleted my system 32 and got my dick stuck in the ceiling fan.
How do i modify the rights in the settings?
https://linustechtips.com/topic/532613-can-not-edit-c-drive/#findComment-7069504
On the entire drive settings you should be able to change permissions to allow access (just like on each file)
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/532613-can-not-edit-c-drive/#findComment-7069520
I get error messages
http://imgur.com/a/SNkGA
https://linustechtips.com/topic/532613-can-not-edit-c-drive/#findComment-7069556
Try instead then on one level lower, say like per folder. Only one should have the errors you are seeing.
https://linustechtips.com/topic/532613-can-not-edit-c-drive/#findComment-7069582
