I use an R9 390
All settings are maxed, except Nvidia hairworks, that one is completely off.
I run it at 45 - 60 FPS with max settings
However, whenever I turn nvidia hairworks on for Geralt only, I drop to 20FPS so I don't even want to try it for everyone.
Why is this drop in frames? Nvidia technology compatability issues or what?
||| Drakon (Desktop Build) |||
|| CPU: 3800X || Cooler: Kraken X63 || Motherboard: B450 Aorus M || Memory: HyperX DDR4-3200MHz 16G ||
|| Storage: 512GB 970 Pro + 500GB 850 EVO + 250GB 850 EVO + 1TB HDD + 2TB HDD || Graphics Card: RX 5700 XT Red Devil || Case: Thermaltake Core V21 || PSU: XFX XTR 750W 80+Gold ||
https://linustechtips.com/topic/531789-witcher-3-question-about-graphics-settings/
No, HairWorks is just garbage. It does the same on a GTX 970.
Turn down foliage visibility range from ultra to high and get free 5-10FPS with no difference in looks basically
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Set foliage to low and you should be good.
i7 7700k @ 4.9ghz | Asus Maximus IX Hero | G.skill 32gb @ 3200 | Gtx 1080 classified | In win 909 | Samsung 960 pro 1tb | WD caviar blue 1tb x3 | Dell u3417w | Corsair H115i | Ducky premier dk9008p (mx reds) | Logitech g900 | Sennheiser hd 800s w/ hdvd 800 | Audioengine a5+ w/ s8
If you want the best possible experience. Set foliage to low and the rest of your settings to high. There's no real discernible difference between high and ultra.
Edited by eLucid
While I agree with your opinion for OP's settings, there is a pretty noticeable difference between High and Ultra for view distance. Like for me it's pretty easy to see the foliage distance, even on Ultra it's really obvious. But that's just my two cents on that one.
Please be serious. Instead of your opinion, why not post screens for hard evidence?
I'm at my campus sitting in a lecture hall listening to the professor telling us about the syllabus and handing us our first homework assignment.
Well, when people "play" games they generally aren't focusing on such minuscule details. That is unless you have your face pressed up against the monitor.
I actually sit really close to my moniotrs. I also am really nitpicky about detials.
It's pretty hard to see the difference man. http://international.download.nvidia.com/geforce-com/international/comparisons/the-witcher-3-wild-hunt/the-witcher-3-wild-hunt-texture-quality-interactive-comparison-1-ultra-vs-high.html
To each their own.
Also, I'm pretty sure this is in the wrong sub-forum.
@Godlygamer23
Edited by eLucid
Since no one has actually answered the question:
Nvidia hairworks renders the hair strains using 64x tesselation.
Nvidia cards are faster at tesselation and as such perform less bad when hairworks is turned on (Nvidia cards loose some FPS too, just not as much).
AMD added a setting in Catalyst (and now in Radeon Settings) to force a lower tesselation level.
Forcing 16x tesselation looks almost the same as 64x while having way better performance.
8x is even faster but does give a descrease in the quality of the hair.
If you are running the latest AMD drivers (Crimson):
  1. Open Radeon Settings
  2. Click on Gaming (bottom menu bar)
  3. Click on The Witcher 3
  4. Change tesselation mode to "Override application settings"
  5. Set "Maximum Tesselation Level" to 16x or 8x.
  6. Enjoy higher framerates
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
And what vague question would that be? You chimed in with helpful advise. As did, @Morgan MLGman.
I use an R9 390
 Seems like a pretty clear question to me...
It's because hairworks uses an extreme form of tesselation. AMD GPUs aren't built for tesselation. They are however built for Asynchronous compute which is a HUGE DX12 feature that Nvidia does not have. You can get decent performance with hairworks by forcing tesselation to 16x from crimson menu. It'll look almost as nice, but your averages will drop to the mid 40s @1080p.
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
Hairworks is a pretty intensive setting. For AMD cards, and most Nvidia cards, I'd leave it off completely. I'd also recommend dropping shadow quality from ultra to high, as the difference in quality is small but the difference in performance significant. In fact, my overclocked 290 (effectively your 390) could get mostly 60 FPS with everything on maximum, save shadows and hairworks (which was off).
Not really. Nobody uses hairworks because it simply isn't worth the performance hit, period! He wanted to improve his frames and most of us here answered his questions that would otherwise greatly improve his performance.
Edited by eLucid
Thats exactly what i posted, scroll up pls
No, he literally asked "Why is this drop in frames? Nvidia technology compatability issues or what?" referring to the Hairworks.
Everyone answers about which OTHER settings to lower instead of answering the real question: why is hairworks slow?
Yeah. I quoted the wrong post lol. He hasn't replied yet but you all definitely gave him a good explanation
I use Hairworks and love it, please don't speak for me.
If anyone asks you never saw me.
Aww, how cute. You got offended enough to reply with such a weak ass remark. Most people that care about performance don't use hairworks. There, you happy? Christ, the overly sensitive beta's are out in full force tonight.
@mathijs727 - I'm pretty sure everyone on here was thinking he would disable HW completely after many stated their reasons behind it. Truthfully, I had no idea AMD driver settings would be the culprit since I don't own an AMD card.
When did I say I was offend? You assumed, bad habit that. I was correcting you. I've read your posts and you seem to think that your view is fact, what you have is an opinion. Which is fine, but your argument caries more weight if you present your opinions as such.
