Help me evade SATA II
Go to solution Solved by Octavialicious,
Yup. Go for it, exactly what I was going to suggest.
Probably
Found some cheap ones on amazon, and I'm buying a single 500GB ADATA SSD and I should get reads of 500+ MB/s
Also found a $20 card with USB 3.1 and USB type C, thanks for all the help guys! :D
Hey all, I deeply like 1366 but I want some of the newer features. I have 2x 240GB SSD's in RAID, but I am getting heavily bottlenecked by SATA II. Right now I'm trying to figure out a way to get fast storage without being limited by SATA II (so most likely something with PCIe cards etc)
My budget is somewhere around $90 if you decide to keep the SSD's, and the budget would be $180ish if you find something else (so I will sell my current ssds)
I'm up for anything really, mSATA drives, PCIe drives, as long as it gets 500+ read. Thanks :D
edit: I need at least 500GB
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/529342-help-me-evade-sata-ii/
I hate to say it, but I don't think it's technically possible unless you're willing to get buttfucked in the ass by half decent PCIe SSD prices.
https://linustechtips.com/topic/529342-help-me-evade-sata-ii/#findComment-7023360
couldn't we use PCIe raid cards etc?
https://linustechtips.com/topic/529342-help-me-evade-sata-ii/#findComment-7023366
yea, I'm just not sure which would be good
you get cookies if you can recommend one on amazon :P
https://linustechtips.com/topic/529342-help-me-evade-sata-ii/#findComment-7023379
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/529342-help-me-evade-sata-ii/#findComment-7023430
Probably
https://linustechtips.com/topic/529342-help-me-evade-sata-ii/#findComment-7023445
don'r buy some samba or starteck card
https://linustechtips.com/topic/529342-help-me-evade-sata-ii/#findComment-7023513
