Vinyl Wrapping
Go to solution Solved by squirrl,
Ebay. Search for 3m di-noc.
I picked up a roll big enough for my 900d back and midplates + extra for £12.99
http://www.ebay.co.uk/itm/121122104187?var=420145788137&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/52869-vinyl-wrapping/#findComment-708674
Ebay, FrozenCPI, MNPCTech.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/52869-vinyl-wrapping/#findComment-709692
  • 1 month later...
got any pics of the finish look?
Akasa Venom Viper Full Tower Case | Intel i7-3930k @ 3.20Gh | Corsair 240Gb GT SSD Raid 0 | Samsung 23" LED 1080p FULL HD (x2) MSI Big Bang-ZPower II Socket 2011 XL ATX Board | Gigabyte GTX 680 | Windows 8.1 Pro | WD Caviar Red 3Tb HDD | Akasa Venom Voodoo high Performance CPU Coolerr | TP Link Wireless N DualBand | Pioneer BDR optical Drive | Corsair Vengance 16Gb Ram
https://linustechtips.com/topic/52869-vinyl-wrapping/#findComment-922807
Check the latest part of my build log. I havent updated it for a while as i've been having issues with it :( But you can see the backplate done there.
https://linustechtips.com/topic/52869-vinyl-wrapping/#findComment-922850
