Fan side up in case or down out of case?
| CPU: Core i7-4790K  |  Motherboard:  MSI Gaming Z97 GAMING 5 LGA 1150  |  CPU Cooler:  NZXT Kraken X61 |
| GPU: Single 8GB EVGA GTX 1070 FTW |  RAMCorsair Vengeance 16GB (2 x 8 GB) DDR3 1600 MHz |  CaseCorsair 330R Titanium Edition
https://linustechtips.com/topic/528607-fan-side-up-or-down-psu/
If you're putting it on carpet then have the fan Up, or better yet put a piece of cardboard underneath your case. Otherwise have it down.
https://linustechtips.com/topic/528607-fan-side-up-or-down-psu/#findComment-7014474
is your PSU intake filtered?
does your case have space under it for airflow?
https://linustechtips.com/topic/528607-fan-side-up-or-down-psu/#findComment-7014475
Really depends but in most cases (heh cases) down. If placed on carpet, up. No filtered intake, up. No intake, definatly up.
My Build: Night Fury | i5-6600k @ 4.5Ghz | R9 390 | 850 EVO 250GB | 1TB Seagate | H230 Black
Night Theme User
         Hello Fellow Night Theme User | Why Aren't You Using Night Theme?
https://linustechtips.com/topic/528607-fan-side-up-or-down-psu/#findComment-7014484
No fan I can get to grips with but surely some sort of grille somewhere. ¯\_(ツ)_/¯
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
https://linustechtips.com/topic/528607-fan-side-up-or-down-psu/#findComment-7014528
