What case do i have?
Go to solution Solved by FloRolf,
some cheap-ass OEM case.
I have a prebuild pc (i know its better to build yourself i didnt bought it is were my parents)  and i would like to know what case i have. the pc is called: "MEDION Erazer X5347 E Intel Core I7-4790"
this is a link to my local shop (http://www.mediamarkt.be/nl/product/_medion-erazer-x5347-e-intel-core-i7-4790-1426242.html) i am hoping someone can help me :). but i dont think so
https://linustechtips.com/topic/526616-what-case-do-i-have/
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/526616-what-case-do-i-have/#findComment-6989860
Probably some proprietary case, meaning there is a chance normal motherboards would not fit into it.
Dont think the case is available otherwise
https://linustechtips.com/topic/526616-what-case-do-i-have/#findComment-6989870
thats what i was afraid off, so i need to buy a new case if i want to upgrade my motherboard to have 2 pci slots
https://linustechtips.com/topic/526616-what-case-do-i-have/#findComment-6989884
-snip-
Note: Never buy medion PCs. Just don't. They are simply not worth their money. I made that mistake once and the only thing that is still left is the screen and even that needed to be repaired because some capacitors fucked up.
But that case looks like a normal ATX case or am I mistaken?
CPU AMD Ryzen 5 5700X3D | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G
Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GBPrograms: Samsung 990 PRO 4 TBData: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W
Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming
Sound Card: Creative Sound BlasterX AE-5 Plus, System: Edifier R1280DB | Magni/Modi Schiit Stack  | OS Windows 10, 64 Bit
https://linustechtips.com/topic/526616-what-case-do-i-have/#findComment-6989959
i know but my parents bought it as a present and i realy appreciate it but if they would have given me € 1200 ,- i could have made a beter pc for even less money but still i can play gta on high/ultra so whose complaining but i would like to upgrade my videocard because i cant realy run Space engineer on 60 fps and i love that game
https://linustechtips.com/topic/526616-what-case-do-i-have/#findComment-6990002
I don't think changing your hardware would make any difference with space engineer. The game is simply on beta and far from being optimized.
i know but i heard users with amd card just like one of my friends has a better fps rate than user with Nvidea card
https://linustechtips.com/topic/526616-what-case-do-i-have/#findComment-7081566
