Best $150 1080p bezel less monitor
Kobrastachka
What is the best 1080p monitor I can get that has a really thin bezel and vesa mounts for $150?
Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
There are some nice IPS AOC models. I would go for one of those.
^^^ AOC makes some very cheap IPS bezel-less monitors
This one for instance http://smile.amazon.com/AOC-i2367Fh-23-Inch-Frameless-LED-Lit/dp/B009V8F700/ref=sr_1_1?s=pc&ie=UTF8&qid=1452653421&sr=1-1&keywords=aoc+monitor
or this one from Acer http://smile.amazon.com/dp/B0148NNKTC/ref=psdc_1292115011_t1_B00CLZ047Q
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
Do they have vesa mounts? I have seen them around but never found one with vesa.
Acer also makes some good but cheap 1080p bezel-less models, dunno if they have VESA though
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
No, I believe they don't.
Yeah, their value monitors (for the specs like mine) usually don't have VESA mounts.
My friend has something very similar if not the same and it's pretty nice
I'd recommend Asus VX239h because I own one. Colours are amazing and it's compact and, if you use them, the speakers get pretty loud.
