Nothing works unless its launched as admin! HELP !
Solved by techguru,
I just did the upgrade. It was working for a while but recently it derped and needs me to hold its hand while it does stuff.
it sounds like you need to do a clean install of 10..you really should have done it right after you did the upgrade
popularlion ·
Posted in Troubleshooting1 -
CallMe_David ·
FancyPants101 ·
BoBo6107 ·
R_public ·
Posted in Networking14 -
apoyusiken ·
Posted in PC Gaming1 -
6
