What fans to get to replace broken stock NZXT ones?
Solved by Enderman,
Would I really notice a big difference in cooling? I have been running it with the two fans broken for 2 weeks now and my temps are hotter than usual but not anywhere near dangerous. I suppose then positive pressure would be a bigger deal since I wont have the clean the goddamn dust as often.
not a huge difference, you would probably get better cooling then you have now, so I would go with the quiet bequiet fans
and yeah that will reduce dust quite a lot because the entire back panel of the S340 is mesh and a ton of stuff comes in from there
