arch linux wifi problems
Solved by Opask,
No if it worked before, installing some random driver isn't going to fix it.im going to try to install drivers and i have a Dell Wireless WLAN 1520 so which driver would i need? https://wireless.wiki.kernel.org/en/users/drivers
First off have you read the arch wiki page for gnome?
It says that gnome uses its own network manager simply titled 'networkmanager'. It provides a service that needs to be enabled:
systemctl enable networkmanager.service
