Cheapest 144hz 1440p monitor?
Fluffinator
Cheapest I've seen is the BenQ there really doesn't seem to be many options, is that just how it is?
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
There are cheap korean 120hz 1440p monitors.
Acer XG270HU is $453 at MacMall
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
I've got a 1080 benq 144hz and honestly i would rather go for 144hz than 1440p
Why Is it windows 10 not 9?
because 7 ate 9
(say it)
Any links?
Never heard of MacMall
should probably add that the big price changer on monitors is image quality, so you'll probably end up with a pretty shyte panel if you cheap out. (oh, and a monitor stand from hell)
Any links?
http://www.blurbusters.com/overclock/120hz-1440p-ips-monitors/
they aren't that great as you might imagine.
oops
ah overclockable to up to 120hz so not a guarantee, guess I'll pass :(
suggestions?
http://www.bhphotovideo.com/c/product/1185413-REG/asus_mg278q_wqhd_27_display.html
There's an Asus^^^^
I can vouch for B&H. I bought both my 980 Tis there at different times. Good site. Just don't try to order on Saturday. They're old school Jews and close checkout on the Sabbath.
pretty sure I have seen them selling pre-overclocked ones. But they still aren't the best.
I just answered a similar question last night. I had both of the 1080p 144hz 27" displays. The Asus and the BenQ. I preferred the Asus and it was only 2ms compared to the BenQ 1ms. The Asus color and contrast just seemed far better than the BenQ after my own amateur tweaking. And I liked the Asus was easier to enable gamemode with a few presses of a single button vs going through a menu with multiple buttons or setting up a preset on the external scroll thing BenQ has. No clue on the 1440p displays though. I'd probably still recommend the Asus based on my experiences with the two 1080p models. I use a Samsung 4K TN now. So, def not a Asus fanboy.
