Hey guys, My GFX card is at 44 at idle.....
Kinda high yeah? Also, My card hits like 60 under load but at 100% speed.
Custom Fan temps https://gyazo.com/93f10e88b55a12bab47f13b78b5d2596
Idle temps. https://gyazo.com/3c171fe0c0dc5b7cc919b6cce1375e50
MSI 980Ti
CPU : i7 4790K // GPU: MSI 980Ti 6G // CPU Cooler: LEPA AquaChanger 240 // MOBO: Gigabyte GA-Z97X-SLI // RAM: 16GB HyperX Fury @ 1866 //    Case & PSU // Fractal Define S & EVGA 750W
https://linustechtips.com/topic/524056-980ti-idle-temps/
MSI 980Ti
Its fine, as long as you don't ldle to hot. (over 80) It is still good. Its designed to run hotter. If you let it go to 80c in games than it would not require the fans at 100%
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957858
That is pretty normal. My 980 idles at 50C with the fans at 0. At 100% load it sits at 70-72C at 80% fan speed. As long as its under 75 ish under load you are good. Nvidia says the cards can operate safely at 81C.
CPU: i7 6700k | Motherboard: MSI Z170A Gaming M7 | RAM: 16GB DDR4 G.Skill RipJaws V @ 2400mhz | GPU: MSI GTX 980 Twin Frozr | Case: Corsair 300r windowed | Storage: 1TB HDD and 128GB SSD | PSU: Corsair RM850i | Monitor: BenQ xl2420z | Cooler: Corsair h60 | Sound: Astro A40 | Mouse: Razer Taipan | OS: Win 8.1 | PCPartPicker Link: http://ca.pcpartpicker.com/p/xV7tZL
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957865
What should I set the fans at? Like, the x fan speed @ x temp?
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957866
ALSO, Should all games use 98 - 100% power?
Yes. Its good that your GPU is using every thing it has in games.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957883
My GTX970 sometimes does that too.
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957884
Mines at 38c right now idling and under load i go any where from 65-73c
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957891
The "auto" fan setting should be ok. If you want to change it you can make a custom fan profile in MSI afterburner.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957893
Okay, then there's something wrong. Some games only use 80 - 90% unless that's fine.
I try and use NZXT CAM to see everything but some games wont allow it.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957897
MSI 980Ti
Load temp is a tad bit high maybe? What do you mean MSI? What cooler does it use? Reference? Twin Frozr?
My idle is 53C fan off. Load temp with 100% fan speed is 55-56C I believe.
What's the temp on load with auto fan profile? Does it throttle?
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957903
My idle is 53C fan off. Load temp with 100% is 55-56C I believe.
MSI Gaming 6G Twin Frozr.
Temp with auto, not sure.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957914
You should make a gentle curve up, so at 60c fans should be at 60%, and at 80c it should be at 90%, and 85c it should be 100%
And no, it should not use 98-100% in low end games. But for high end graphically intensive games then yes its normal. Like BF4, Far Cry 4, fallout, battlefront, R6 siege. But also if you have a 60 hz monitor than running past 70 fps is a waste of energy and cause more heat. I am not sure what nvidia has but something equivilent to FTC from AMD. Would help.
It is kinda hot though, I tested a 980ti G1 gaming and it was at about 65c at 50% fan in battlefront.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957919
In older games your GPU might not hit 100%. This is ok as long as you are not getting terrible FPS. However if you are playing more modern games that are demanding and you are not getting high 90% GPU usage it might be a sign of a bottleneck, or something wrong with your card.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957921
Hm, okay. What's the best to see % used. NZXT Cam only works with some games.... Really annoying
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957931
DayZ only uses 40% of my GTX970 and plays at 20fps on highest settings.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957935
I would not recommend running your card at over 80C. This high temp for long periods of time might shorten the life span of the card.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957941
Thats because it is a terribly optimized game.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957948
I have a 144hz monitor on 120hz. I was just worried about temps. What can I use to stress without paying for firestrike and I can get back to you guys...
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957960
furmark
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6957989
furmark
Okay. I ran 10,000 frames and took a SS but i'm not sure where it saved. This is after 10k frames on the 1080p preset with 4x MSAA @ 1080p.
https://gyazo.com/7a0d9c325d9ae2aeaa57b0bccae5629c
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6958054
Yeah I know.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6958103
You should run it for a little longer. It looks like the temps have not yet stabilized yet. Do a 10 min test and see where the temps get.
10,000 frames is a benchmark. You want to stress test.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6959071
Alright, I'll run it tomorrow and let you know.
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6960176
45° idle 70°@70% under load
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/524056-980ti-idle-temps/#findComment-6960512
