Drawing on side panel H440
Solved by Darkscooty,
I would very much appreciate this
Sorry its been a long 24 hours......
I am just having a look for you now. in the mean time have you thought about messaging www.dbrand.com/ ? Use there contact us page and email about a customer skin? provide the measurements of the side of case and where you would want the picture. While you do that I will look for more solutions for you.
