Fluctuation is normal. Those temps however seem a touch high if you are running it at stock speeds. I would try re-applying the thermal paste and making sure it is properly seated.
That all being said, the temps are totally acceptable and wont harm your computer, I just feel like they could be a little lower with that cooler. When i say a little, i mean like less than 10 degrees.
When in doubt, re-format.
https://linustechtips.com/topic/522405-corsair-h100-temps/#findComment-6937400
I will try that, and i hope i can lower the temps because it will have a meaningful difference for when both of my GPU's are on a high load.
https://linustechtips.com/topic/522405-corsair-h100-temps/#findComment-6937415
step one is to stop using prime 95
set two is to run a stress test like aida64 or intel XTU and see what your max temps are then
https://linustechtips.com/topic/522405-corsair-h100-temps/#findComment-6937422
This is after running Intel XTU for 10 mins.
attachicon.gif076cc3648fc4caf47226075e53cd374d.png attachicon.giffd7d0537390d21e9e32e7d3c74fa0723.png
looks good
https://linustechtips.com/topic/522405-corsair-h100-temps/#findComment-6937519
