test the onboard before buying the audio card
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/522141-sound-card-vs-onboard/#findComment-6934254
it will probably be worse
https://linustechtips.com/topic/522141-sound-card-vs-onboard/#findComment-6934264
The only worthwhile successor to onboard these days is spending the $200+ for the high-end of sound cards. So if money is no problem and you want the BEST internal solution you can get, then absolutely a $200 sound card will do the trick. That said, for $99 you can get a Schiit Magni 2 which would be far superior to that of say, the Creative ZxR that I use in my pc.
Onboard has gotten better over the years and will possibly continue with that trend, but without spending $200, chances are your onboard is better than other internal options.
MSI Z97M Gaming | i7-4790k | NZXT Kraken X61 | 16GB Kingston Savage DDR3 2400
EVGA GTX1080 Ti FTW3 | EVGA G2 750 | Phanteks Enthoo Evolv | 1TB 850 Evo | 2TB 860 Evo | 22TB DS918+
Scarlett 2i2 | WooAudio WA7 Fireflies | Fostex TR-X00 | Beyer DT990 | MrSpeaker Alpha Dog | V-Moda M-100 | JBL LSR305 MK2
https://linustechtips.com/topic/522141-sound-card-vs-onboard/#findComment-6934295
I'm looking at a $40 Creative pci-e sound card and was curious if it will be that much better than the onboard audio for 5.1 or 7.1? I'm using the MSI Krait Z97 motherboard and Sennheiser HD558 headphones. Thanks guys!
Honestly, you're not going to see any increase in quality, if it is even an increase at all. IF you want something extra, go with an external USB DAC, as it is isolated from the PSU completely.
COMPUTER: Mobile Battlestation  |  CPU: INTEL I7-8700k |  Motherboard: Asus z370-i Strix Gaming  | GPU: EVGA GTX 1080 FTW ACX 3.0 | Cooler: Scythe Big Shuriken 2 Rev. b |  PSU: Corsair SF600 | HDD: Samsung 860 evo 1tb
https://linustechtips.com/topic/522141-sound-card-vs-onboard/#findComment-6934324
