Hey guys, one of my friends is having trouble with GTA 5. In the game he gets exactly 1 fps and it never goes over.. He has everything up to date and every other game runs extremely well including Arma 3 which is a demanding game, he can run that at 60fps on Ultra no problems..
Here are the specs -
CPU
    Intel Core i5 2500 @ 3.30GHz
    Sandy Bridge 32nm Technology
RAM
    16.0GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
    Gigabyte Technology Co. Ltd. P67A-UD4-B3 (Socket 1155)
Graphics
    DVI (1920x1080@144hz)
    2048MB ATI AMD Radeon HD 6900 Series (XFX Pine Group)
Storage
    931GB Western Digital WDC WD10EZRX-00D8PB0 ATA Device (SATA)
Main PC/Gaming PC - G3258 @ 4.0GHz | Sapphire R9 280 3gb | 2x4GB Kingston Fury HyperX Blue 1600Mhz RAM | ASRock H97M Anniversary | x2 Seagate Barracuda 1tb | Coolermaster N400 Windowed | EVGA 600B 600W PSU | Windows 8
Keyboard, Mouse etc. - Razer Blackwidow Expert 2014 Green Switches | Logitech G502 Mouse | Logitech G430 Headset | Logitech C920 Webcam |
Screens - Acer K27HL | Acer S23HL | 32" Full HD TV (Don't know brand) |
https://linustechtips.com/topic/521645-gta-extreme-lag/
did you enable "Frame Scaling Mode" by accident?
because 1FPS is absurd
Nope that's turned off. He said its going at 20fps and then pausing and then back to 20fps and then back to pausing
https://linustechtips.com/topic/521645-gta-extreme-lag/#findComment-6927420
Some people have problems with V-Sync in GTA, try turn it off if it's on. If it's off, try turn it on.
Yeah he's tried it on full, half and off and its the same
hmm, that's strange
then try turning AA off if he hasn't already
He has it turned off and still nothing
https://linustechtips.com/topic/521645-gta-extreme-lag/#findComment-6927463
Disable crossfire and check performance?
Okay, will get him to do that now
https://linustechtips.com/topic/521645-gta-extreme-lag/#findComment-6927477
I just want to point out how Arma 3 cannot be used for comparision unless you're talking about the base single player missions as each server has different plug ins and mods therefore, I sometime get 100+fps on ultra then sometimes I get less than 20fps depending on the map and server. So it's best not to use any Bohemia games for comparison reasons :D (plus, it's a CPU bound game)
Has he tried updating his drivers (even though I can't see it helping here), tried turning all the settings to lowest (except resolution), maybe he has virtual super resolution activated?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/521645-gta-extreme-lag/#findComment-6927515
Yeah just thought it would be good to point out! I'll check and see if the Super Resolution is on
https://linustechtips.com/topic/521645-gta-extreme-lag/#findComment-6927533
