First Build Tips and Tricks
Go to solution Solved by iJarbus,
Like others have said a bare table would be better, as for sole general tips:
- set aside a few hours for your first build its better to take it slow.
- build everything outside the case first, just place the motherboard on the box it came in and do a quick post test.
- if your computer doesn't post initially don't freak out allot of people's don't, just check each power connector and check that RAM is seated correctly. More often than not this is the issue.
Hope this helps, if you need help feel free to PM me, good luck.
i have personally recently bought my gaming computer parts and i was looking for tips in the building stage. Mainly for computer safety. one of my big questions is weather a table cloth would help reduce the chance of ESD (Electro static discharge). and otherwise i am looking for general tips and tricks for the build.
Thanks for the help.
Desert_Storm_ :D
P.s please only post tips you know help
https://linustechtips.com/topic/519066-first-build-tips-and-tricks/
Tablet cloth would increase friction which increases static. I work on just a wood table.
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
Specs? Some parts are bit different from others.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
As Luc401 said. Cloth friction creates static electricity. Work on something made out of wood, rubber or built to not build up static.
Theory is when you know everything but nothing works. Practice is when everything works but you dont know why. In this computer, theory and practice are combined: Nothing works and i dont know why.
Atleast i can manage Some things, like my current OC personal best.
Nice case, prefer bigger cases myself as I know it's ME that has to build it, lol... don't like ITX much as it's too small. I would wear some rubber gloves to save your hands a bit when trying to build inside the case, would help a bit with not building up static too. Oh, might just be me (only had a quick look), but that looks like it's going to be a pain to clean the dust off the intake as you have to remove the front panel, hope you have somewhere relatively PC friendly where it's not going to suck in dust like a vaccuum cleaner :)
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Desert_Storm_ :D
If you're worried about esd try this:
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.amazon.com/StarTech-com-24x27-5-Inch-Desktop-Anti-Static-M3013/dp/B00009XT3H&ved=0ahUKEwjOwdmQhI_KAhUDwmMKHWjrDVMQFgg1MAA&usg=AFQjCNEJrtzIIL2rQW6wRghO2TfnhyqjJQ&sig2=wZB5E-Ys-2VFPvL292EJnQ
