Is a sound card worth the money?
Solved by STRMfrmXMN,
No unless you have fancy fancy headphones
Not even then... all they do is decrease the impedance of your headphones which gives the impression of them sounding better when, in reality, they're just louder.
Title says it all.
Nope. Get an external DAC if you feel up for the audio upgrade. This SMSL is great if you're up for utilizing the audio interface and this if you aren't. I'd strongly suggest that Micca though. It has both 3.5mm and 1/4" jacks and is USB and basically an Audioengine D1 in disguise.
