I already posted something on gpu forum about lag im getting (which i think its bottleneck cause my gpu is weak) but then i found out something else
since i put new cpu(phenom ii x4 940) on my mobo(m2n68 am se2), im getting a message on boot which says something like 'Your cpu is not supported by this model of motherboard... Press F1 to continue'
and this is like for almost a year
and now i go to mobo site and check cpu support for motherboard
there was phenom ii x4 945(all stats are same as on 940, same W reqs, same speed, everything) but there wasnt 940 and i remember when i bought the cpu i checked the cpu support list then too but maybe i confused 945 with 940 and didnt payed attention to it
so my question is can this cause the lag im getting in games and can it destroy or burn something on my mobo or cpu?
or can it not use full power of the cpu?
btw i checked on some forums that support between cpu and mobo depends on power, in this case 125W, this mobo can wear 125W cpus as i saw
so im guessing 940 shouldnt be prob
someone tell me if im wrong and what should i do
tnx in advance
https://linustechtips.com/topic/517214-cpu-not-supported-by-mb-model/
However, that motherboard theoretically does support the processor as the X4 940 is a socket AM2+ processor.
I hope that you are right :D
 If I were you, I would pick up a new motherboard that officially supports your processor.
and nowadays its hard to find am2+ mobo with ddr2, if i dont find it, it would cost me a lot of money to switch to ddr3(new ram, new mobo)
check if theirs a bios update. This is how I fixed my motherboard when it wouldn't post even when the website said it was supported with my new i5 as the bios update added compatibility for it .
i updated the bios to the version that is needed for phenom 945
i did that when i bought the cpu
The big difference between the Phenon II X4 945 and 940 -- The Phenom II X4 940 is a "Black Edition" CPU with an unlocked multiplier.
The Phenom II X4 945 is a locked chip.
The microcode between the two are different, and as mentioned before, the Phenom II X4 940 is not certified on the particular motherboard. As a result, the motherboard outputs a warning.
Both are K10 chips, from the "Dragon" platform, and are code-named "Deneb"...but it is the small difference that changes everything.
What games are you noticing performance dips?
From what I can see, the Radeon HD 6570 is most likely the culprit...but just to be sure.
By the way, the Phenom II line of CPUs are capable of handling much higher performing GPU's before it becomes a "bottleneck" effect.
(My Phenom II X6 1090T handled 2~3 HD 5850's and a single HD 7970 with no problems)
Upgrading the platform to AM3/AM3+ isn't ridiculously expensive. You don't need a $180~$200+ motherboard for a Phenom II X4 -- a FX-8000 or FX-9000 is a different story. Plus, you can snag a 8GB DDR3 1600 MHz / 1866 MHz kit for about $30~$40. Heck, you can even find 16GB kits for as low as $65.
Let me work something out on PCPactPicker right now...(just some beneficial info for you).
EDIT:
With a new CPU cooler (Cooler Master Hyper 212 EVO)
http://pcpartpicker.com/p/QM8CNG
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.98 @ OutletPC)
Motherboard: Asus M5A97 PLUS ATX AM3+ Motherboard  ($46.98 @ Newegg)
Memory: Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600 Memory  ($27.99 @ Newegg)
Total: $99.95
Generated by PCPartPicker 2015-12-31 17:01 EST-0500
Without a new CPU cooler
Total: $74.97
Generated by PCPartPicker 2015-12-31 17:02 EST-0500
If a micro-ATX board is a requirement (since your ASUS M2N68-AM is)
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
If you have a AM3 CPU which I think it is then any AM3 or AM3+ will do! What form factor are you gonna use? If full ATX maybe a MSI 970 Krait? (if it use 95W it should be safe but I advice to get a MSI 970 Gaming board if you wanna OC a bit...) Also ASUS is even better but prices... :(
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
MSi 970 Krait will work too...just trying to keep the price down (seemed like cost was a big concern).
Plus, the Phenom II X4 945 is a locked multiplier processor (I don't think the OP is the overclocking kind of person  :P ).
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
Then Krait will do! :D
So i assume i have the black edition now, would it be smart(counting on that i have shit ccooling) to oc it? only the frequency
This should mean my mobo wont get burned or whatever cause of that warning, i mean 940 and 945 are same shit
so far my brother tried Watch dogs, GTA V, fallout 4, ac syndicate, nfs rivals, just to mention that battlefield 4 worked just fine and if i remember right ac unity worked fine too
btw i think i mentioned on other thread that i have a laptop hp 355 g2(its worse by performance then this pc), still i tried watch dogs and gta v on laptop and they work fine constantly
and even when i saw the gameplay on pc, those moments without slowdown, they seemed more, much more smoother then on my laptop
just that 2-3 secs is the prob which gets so annoying
im not sure, but should a 95W mobo be a prob for 125W cpu?
btw i think i cant take any am3 mobo since most of am3 mobos are ddr3 if im not mistaken and phenom 940 goes only with ddr2
All AM3 mobos are DDR3 except for a few older ones with both? :P And yes then you need MSI 970 Gaming if its 125W...
yea am3 goes with ddr2 and ddr3
am2 and am2+ go only with ddr2
and i just checked that msi 970 krait doesnt support this cpu neither, despite it supports all other phenom ii x4s :(
i get that somehting is wrong with this damn cpu :P
like its missing from database hahahahah xD
MSI 970 Gaming AM3+ its also not listed there... :( (is there a made in China sticker on it?)
hahahhaahhahaha
Check ASUS boards? :D
i found this one http://www.gigabyte.com/products/product-page.aspx?pid=2690#ov as a match
but who knows if i find it in shops
If not in shops there is always Amazon and Ebay... (used is risks...) :(
@pakjoni
Yes, the Phenom II X4 940 is indeed a "Black Edition" Processor.
http://www.legitreviews.com/amd-phenom-ii-x4-940-processor-review_860
http://www.trustedreviews.com/amd-phenom-ii-x4-940-review
http://www.anandtech.com/show/2702
Given that motherboard and the CPU cooling system you have now, I strongly advise that you NOT overclock your Phenom II X4 940 -- to the point it is simply unsafe for YOU and the computer. I am being serious here.
Most (if not all) fully AM3 motherboards will only have DDR3 RAM support. As I mentioned before, DDR3 has come down in price, and will soon be phased out -- reduced production, causing price increase -- and you can get a 8GB (4GB X 2) for as low as $28. Buying a brand new DDR2 4GB (i.e. 2GB X 2) kit is even more expensive.
This is why I am encouraging you to actually jump in the AM3/AM3+ platform, and get an inexpensive DDR3 memory kit. Plus, your current ASUS motherboard only supports a maximum of 4GB (2GB X 2) anyways.
DDR3 RAM support was one of the key highlights with AM3 on the new (at the time) 890FX chipset -- it was the new technology trend, exactly like DDR4 now at the present time.
The Gigabyte GA-MA790FX-DQ6 is a very nice motherboard -- especially back during its debut.
It uses the top tier 790FX chipset available (790FX followed by 790X, 790GX, etc, etc); this chipset is intended for overclocking and using multiple graphics cards.
That is why there is proper cooling over the 8+2 VRM's (the big copper heatsink + heatpipe), and serveral PCI-Express X16 expansion slots.
You probably won't be able to find it brand new in stores anymore, though; the 700 series chipset is already two (almost three) generations old now.
The 790FX has already been replaced by the 890FX, and the 990FX.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
about that
i still cant find place wheere it says my cpu is BE
and is a aluminum heatsink with copper tubes still good?
The Phenom II X4 940 is, for sure, a "Black Edition" Processor.
Windows or the motherboard BIOS will not indicate this -- though the CPU multiplier option will become available to you in the BIOS under the overclocking section.
The professional reviews I linked to indicates the Phenom II X4 940 is a BE chip.
Additionally, when you purchase the boxed retail version of the Processor, it indicates this.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103471
Basically, a "Black Edition" CPU will have a black-coloured retail box, with "Black Edition" and "overclocking" or "unlocked" written all over it.
The non "Black Editoin" Processors had a much plainer packaging.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103675
The stock aluminum, and copper heatsink cooler from AMD, will be sufficient for mild overclocks. If you want to push your Phenom II X4 940 into the 4.0 GHz range, you will need a better CPU cooler (i.e. the Cooler Master Hyper 212 EVO that I previously mentioned).
For future reference, the  Phenom II line of processors does not overclock to as high of a "GHz" compared to the more recent chips.
A majority of them could only reach 3.8 GHz ~ 4.0 GHz.
For an example, my Phenom II X4 955 was only able to reach 3.9 GHz under sustainable temperatures and voltages...while my Phenom II X6 1090T (that I still dearly have) only reached 4.1 GHz with 1.47V with the Core Voltage.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
yea ive heard that 212 evo is pretty good
everyone recommend it
eitherway im not trying to oc it just maybe if i get a better cooler maybe the lag im getting will be gone
i saw some videos on yt, gameplays actually, with this cpu running some pretty demanding games easily
just with better ram and gpu then me ofc xD
and i think phenom IIs are pretty awesome and strong
The Cooler Master Hyper 212 EVO is a very good cooling system for the price. In several cases, it outperforms even some of the ~$40 (or more) CPU coolers.
The Phenom II X4's are "true" Quad-cores, opposed to the socket AM3+ FX line of Processors.
Believe it or not, the per-cycle (IPC) performance on the older Phenom II "Deneb" and "Thubans" were actually better than the first little bit of Am3+ FX chips.
Basically if you compare the Quad-core Phenom II X4  to a Quad-Core FX Processor, given they have the same amount of cache, and frequency (i.e. both 3.2 GHz), the Phenom II actually performed better.
If the CPU or the motherboard is thermal throttling, then you still notice a hit in performance, but if that is not the situation, then it may be due to slow CPU / GPU / HDD / internet, etc.
The Phenon II CPU's are still pretty good performers, but of course, they won't be able to compete with something like the much newer Intel Core i5 or i7's (i.e. i5-4690K or i7-5960X). Plus, the chips are already nearly 8 years old, so they do show their age a bit.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
