My PSU has 2 caps that are bulged on the top and liquid was coming out. Its now dried up but both caps remain in the system. i was thinking of replacing the caps because it would be much cheaper than replacing the PSU that btw with 2 damaged caps still works. I do know how to replace caps but I have never done it myself. Should I replace the caps? I think it would be a fun little project but i do have to do something about the thermals inside the PSU because the caps died from overheating because both of them are right next to some heatsinks that get very very hot due to my GPU pulling more power then the PSU was originally meant to give out. So far i can't find anything wrong with the unit other than 2 bad caps some some hot heatsinks. if I can replace the fan with a better one for cheap and replace the caps for a few cents that would be fine with me because i don't have 80$ for a new PSU.
https://linustechtips.com/topic/51590-to-replace-caps-or-not-to-replace/
Dude! You said you were gonna replace that thing! GO AND DO IT! I don't want you to blow up!
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
Do NOT, I repeat DO NOT mess with your PSU, Replace it.
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
Replacing caps are easy, if they blow you may as well replace them.
Just replace it, get a 80 Plus 500W/600W PSU From someone like corsair or Seasonic, you can find then for around 50$
Caps are cheap as dirt.
Basic electrical work like replacing caps is not that big of a deal......... Although his psu does blow and needs to be replaced.
Some months ago, a guy died electrocuted, trying to repair his psu. Unplugged and turned off
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
I'm broke so i might replace the caps thats the only thing wrong with it.
I think dirt costs more xD
I know what i'm doing for the most part I love watching EEVBlog.
Well that guy must have been pretty stupid and touched the big filter caps I only need to replace 2 really tiny 16v caps.
Still won't be worth it, because that PSU is probably going to die or die very soon
Other the the 2 bad caps everything is 100% fine.
Touching caps can kill you?
If it's charged or something
Only big caps are a problem the tiny ones discharge pretty quick and aren't really dangerous at all.
So you may as well try to fix it to get the rest of it's life out of it.
The caps are failing becuse you have over strained your PSU, in doing so you may have damaged other components so this PSU is now unsafe, please replace asap, also running it with damaged caps, means it cant possibility be outputting a clean signal so god only knows what its doing to your hardware.
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
The caps are bad because they are nearly touching a heatsink thats gets to hot and they are swelled up not because the caps are overstrained
That's what I'm thinking. If the caps are in this state, just imagine how the other components are.
Everything seems fine I haven't actually probed anything but visually everything seems not burnt xD
Your PSU is connected to all your lovey hardware, why risk it?
If they have swelled they are failing regardless of the cause... if yoiu overstrain a cap it gets hot... same outcome different cause...
If you can do it then great replace away!
But, you really need to figure out why those caps are bad, not just replace and think all is well, they can just blow again after a short while if the issue that caused them to blow is still there. Not that you have other issues but need to check things out while you have it open.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
I always advise to not try to replace caps in a PSU. If you do, leave it unplugged for a day because the residual charge in the caps can give you a pretty hefty zap.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
RENTON! Don't do it! The Nirvash isn't worth the risk of replacing the Compac Drive!
[TRUENO] i7 4770k (~4.4Ghz, 1.28v) || Thermalright Macho 120 || Asus Z87 Gryphon || 2x8Gb Mushkin Blackline|| Reference NVIDIA GTX770 || Corsair Neutron GTX 480GB || 2x3TB WD HDD || Corsair 350D || Corsair RM750
