you need to have a compatible CPU socket to mount the CPU block and a compatible case to mount a radiator
https://linustechtips.com/topic/515752-water-cooling/#findComment-6859498
Which is basically every CPU Socket in existence :P
And congrats on that 24,000 posts :)
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/515752-water-cooling/#findComment-6859510
In theory all cases have atleast a 120mm space for a rad at the back so I guess so?
https://linustechtips.com/topic/515752-water-cooling/#findComment-6859511
thanks :P
if op is using a 10 year old PC with some ancient socket then no, there arent watercoolers with mounting hardware for those
https://linustechtips.com/topic/515752-water-cooling/#findComment-6859519
