does minecraft not like maxwell gpus?
doing just fine with 300+ fps on 4k w/ a Fury X/390 >.>
Then again, i'm also running a large modpack, and optifine.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
i cant seem to get over 100 fps most of the time 50 fps with my new 980 and with my 760 i got 600+ fps sometimes over 1000, is minecraft/java not optimised for Maxwell gpus? im using optifine to
Are you using 64 bit Java? That's the only thing I can think of.
Make sure you go into your java setting and allow minecraft to use ALOT of memory, i have my java settings allowing minecraft to use 12gb of ram out of the 16gb i have... ive seen it use over 7 gb before
no difference in fps with 10gb from 5gb
Minecraft loves CPUs though
Everyday build:
CPU: Intel Core i7 5960x - GPU(s): 2x EVGA GTX 980 Ti Superclocked+ ACX2.0+ (SLI) - Cooler: be quiet! Dark Rock Pro 3 - Motherboard: ASUS Sabertooth X99 - RAM: 32GB Kingston HyperX Fury Black DDR4 4x8GB (2666MHz) - Storage: Intel 750 Series 1.2TB + 4TB WD Black - Case: Corsair 760T White - PSU: SeaSonic 1200W 80+ Platinum Certified - OS: Windows 10 Pro - Wireless Adapter: TP-Link Archer T9E - Monitor: Acer XB270HU bprz - Keyboard: Corsair K70 RGB - Mouse(s): Corsair Gaming M65 RGB + Logitech MX Master - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/WhyK99 https://linustechtips.com/main/topic/474247-r8-my-build/
Weekend build:
CPU: Intel Core i7 5930k - GPU(s): 2x EVGA GTX 980 Ti Classified ACX2.0+ (SLI) - Cooler: NZXT Kraken X61 - Motherboard: ASUS X99-Deluxe - RAM: 32GB Crucial Ballistix Sport LT DDR4 4x8GB (2666MHz) - Storage: Samsung 950 Pro 512GB m.2 & 2TB Samsung 850 Evo - Case: Phanteks Enthoo Evolv - PSU: SeaSonic SnowSilent 1050W 80+ Platinum Certified - OS: Windows 10 Home - Monitor: Dell S2716DG 144hz - Keyboard: Corsair STRAFE RGB - Mouse: Corsair Gaming M65 RGB - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/YYK93C
Too much FPS, had to nerf it to make it more cinematic.
r9 270x 4GB gets around 600FPs aswell lol
(OC'd to the max of course)
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
The problem is the GPU idles and it causes a performance reduction. What you need to do is in the Nvidia control panel is change it to maximise performance for minecraft and it'll fix the FPS. You can also force the GPU to run by using shaders if you like, you have the spare capacity and it'll oddly enough improve the frame rate.
