So I was wondering does surround sound give you an advantage while gaming( I Mainly play csgo) and is there a difference between virtual and actual surround in terms of sound and is the difference between 5.1 vs 7.1 surround significant?
Thanks for your help
no. it is terrible
you can get better positional audio from a good pair of headphones.
hence why only "gaming" companies use surround sound in headphones.
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/515221-surround-sound-questions/#findComment-6853454
Why is it terrible? Isn't it just more speakers in different angles?
it is two speakers with surround enabled by software...
trust me you get better audio quality and positional audio from proper headphones..
audio technical ad series have good positional audio iirc
https://linustechtips.com/topic/515221-surround-sound-questions/#findComment-6853661
no. it is terrible
Have you ever listened to a good 5.1 setup?
7.1 is just making the sweet spot bigger.
If you are sitting in the sweet spot there is no difference between 4.1 and 7.1
https://linustechtips.com/topic/515221-surround-sound-questions/#findComment-6859051
no. it is terrible
Well, unless you are talking about real speakers.
https://linustechtips.com/topic/515221-surround-sound-questions/#findComment-6865707
