for audio with my system I currently use a Astro A40 with the included mic I got as a gift.
Im curious of the suggested "upgrade paths" for my audio. particularly my mic. How good is the mic included? would something like a mod mic be a worthwhile upgrade? Keeping in mind I like clicky mechanical keyboards.
What would be a good combo for a good pair of dedicated headphones and a dedicated mic if I were to get rid of my current setup, with a budget of around $150 (maybe $200 if its a big step up)
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/513935-audio-upgrade/
Your biggest upgrade in audio would be a DAC/Amp
The a40 mic is pretty bad from the last time I used one.
Blue snowball is 50ish for a standalone mic
Headphones, HD 598s are a nice pair and between the two that would be your 200.
CPU: I7 5960X @4612 MHZ/1.325Vcore | Cooler: Full custom loop | Mobo: Asus X-99A | GPU: 2 EVGA 980 TI Classifieds | RAM: G.Skill Trident Z 32 GBs 3200 MHZ | Storage: Samsung SM951 512 GB M.2 Drive, Mushkin Eco2 512 GB SSD, Muskin Chronos 480 GB SSD | PSU: Corsair HX 1000i | Case: Fractal define R5 | Monitor: LG 34UC87M-B
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6840762
I'v been using my Astro A40 mic for a while now, and it has been great. Obviously not the best microphone out there for headsets, but much, much better than most.
You could get a mod mic, but I really don't think it's worth it over the Astro mic.
If you're doing Youtube videos, I would get a Blue Yeti or Snowball, if not stick with the Astro.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6840769
You aren't talking about using a DAC/Amp with Astro's are you?
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6840774
Lord no LOL
Was just giving OP some ideas to play with.
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6840789
Lord no LOL
Hahahah, I thought so.
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6840794
Speaking of which.. mine are on the floor next to me... dunno what to do with them
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6840807
Can you elaborate on this?
I would suggest that unless spending about $1000 in total, there is little point in spending money on a DAC at all, and unless spending $150-200 total, there is no point in spending money on an amp.
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6840816
The modmic is perfectly fine if you're just using it for gaming. If you're recording/producing, consider getting a Yeti/AT2020/Snowball. Those are all great choices, and combined with a cheap boom + shockmount are flawless.
For headphones, I'm going to do what I always do and recommend the HD 598s. I've had mine a little over a year and they get a 10/10 for comfort, reliability, and sound quality. You can always combine them with an AMP/DAC if you wanted, but that's totally not needed.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6840817
Keep in mind that if you do go for a dedicated headphone and a dedicated desk mic, your friends will hate you if you don't use push to talk...just saying.
Anyway, if we go by your reach budget, you can grab something like a Blue Snowball ICE, and still have 100-150 to spend on a pair of headphones, what music do you listen to?
I'm tempted to recommend the Audio-Technica ADG1, unfortunately it's out of your budget unless you choose to go with the various Amazon warehouse deals for about $160 (Don't like the AG1, If the AG1 is anything like the Ax line of headphones it's based off of, it's going to be heavy and the elastic mod is almost required)
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6841431
I see no reason to pay $200+ for ADG1 when it's literally an ad700x with a mic attached.
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6841540
Which is why I didn't recommend paying full price for it.  The Amazon warehouse deal is $160, sure a 700x + a Snowball is still cheaper, but it creates the push-to-talk problem I mentioned.  It's a good compromise.  At 260 dollars for a new pair it's steep, I know, I don't have the AT fanboy name on top of me for nothing.  But if you're willing to get it used, $160 for a complete package (Headphones, Mic, and a USB soundcard just in case your onboard sucks), is a good deal.  At the end of the day, it's not just about saving money, we can't just regurgitate everything we say a million times, we have to look at the the situation and take into account what the OP is actually looking for.  My recommendation was based off of OP's prior usage of the A40s and OP's interest in the Mod Mic, and my educated guess that he's mainly going to be using this for gaming.
tl;dr, I know it's bad value to us, but I think my recommendation is sound nevertheless taking into account the situation.
Speakers - KEF LSX
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6841657
Not at all... Ad700x new is only $100 and with the modmic it's still cheaper than ADG1 used. And what push to talk problem? If you mean the mic would picks up noise from the open headphones, I see no reason why the ADG1 wouldn't have the same issue. Also, it is indeed about saving money if you're paying more for the same thing for no reason.
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6841818
If you're asking about upgrade paths for mics, then you might want to look into getting an audio interface and an XLR mic.  Once you get a USB mic there is no more upgrading, you have to replace the whole unit.
Here's a video explaining audio interfaces.https://youtu.be/_sjZJ9i_mH0?t=235
https://linustechtips.com/topic/513935-audio-upgrade/#findComment-6843783
