Where are you mounting that?
Only on the front of the case supports 2x140/120mm fans.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
Use some zipties if you are trying to mount it in a place without support for a 140mm fan.
4790k @ 4.5Ghz 1.180v NZXT Kraken X31 | MSI Z97 Krait | Kingston Hyper X Fury 32GB 1866Mhz, 2 DIMMs white and 2 black | GTX 980 Ti - G1 Gaming | GTX 680 - Reference | SilverStone ST75F-P | Phanteks Enthoo Pro
So ghetto xD
It will only match the LTT fan so much more.
Thats where I'm trying to mount it!
What is the exact problem you are facing?
Posing pictures could help us understanding the problem that you're facing.
rip @LinusTech
your fans are worthless itsa over  close the company
rip ltt
/t
I don't have the spec-01 but from the way I see it you need to pop the front bezel off and mount the fan using the long screws, not the short ones.
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
