Need help!!!!!!!!!!!!!!!!
Ok here is the deal. My parents work pc got the blue screen of death. Then they booted it back up and it went white and shutdown. So I am trying to fix it(always me). This is the pc http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01926404〈=en&prodSeriesId=4047689. So every time I try to boot it recognizes the keyboard, and then the monitor goes to sleep and the keyboard does not respond. I have tried moving ram around,new cords,keyboards,graphic cards etc etc etc I dont know what to do. this happened once before about 4 months ago.
​Any help is very appreciated:)
Sry for the long link.
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/5126-need-help/
With the case off, when you power it up, do the fans spin up and stay spinning, or is it powering down completly?
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/5126-need-help/#findComment-59256
If you can try removing one of the ram sticks, or replacing them, reset the bios by removing the battery, and try using the onbaord video if it has a vid card in there,you can also try a different PSU, if none of these work it is quite possibly the motherboard has died or the CPU has pooped it self like Samdb has said.
CPU- I7 7700K @ 4.4Ghz, RAM- 32 Gig Hyper X @ 2800 mhz , GPU - GTX 1080ti Strix 11gb , MOBO- Asrock Fatality Z270 , SSD :Kingston Hyper X SSD Fury and Samsung 500gig
https://linustechtips.com/topic/5126-need-help/#findComment-59261
They spin up and run fine.
https://linustechtips.com/topic/5126-need-help/#findComment-59309
As I thought it could be anything....
https://linustechtips.com/topic/5126-need-help/#findComment-59310
What'd you do to fix it last time?
I didnt have to fix it.It booted back up.
https://linustechtips.com/topic/5126-need-help/#findComment-59311
Yep - going to need some spare componentd and test everything. Problem is - that system is all custom, as is much of HP business systems. They even use custom pinouts on new business PC's so you cannot use a standard PSU even. Did you check the serial number with HP and see if it is still under warranty?
Try running with just one ram stick... swap and see if anything works.
https://linustechtips.com/topic/5126-need-help/#findComment-59317
Hi
What OS is the computer currently running ??? Have you just tried another screen? It is possible the monitor is Dead. Also are you getting any beeps? If so how many ?
Is the heat sink clear of dust?. Have you tried taking everything out and the cleaning and placing it all back in? Is the keyboards number lock lighting up?
MB: Gigabyte Auros Gaming 7 Z370 Cpu: Intel i7 8700K @ 4.8ghz Gpu: Gigabyte GeForce GTX 1080 G1 Gaming OC 8GB Ram: Corsair Vengeance LPX 64GB DDR4 DRAM 2400MHz  Psu: Corsair RM1000i
Ssd's: WD Green nvme m.2 512gb (boot), 480gb (Steam), 480gb (Uplay) and 480gb (Origin)  Cooling: Corsair Hydro Series H115i 280mm
 Case: Corsair Obsidian Series 900D Monitors 1: Asus pb287q @ 75hz
https://linustechtips.com/topic/5126-need-help/#findComment-59318
Yep.....
https://linustechtips.com/topic/5126-need-help/#findComment-59385
Hi
We just installed windows 7. Yes I have tried a new monitor. Yes I have cleaned it.
https://linustechtips.com/topic/5126-need-help/#findComment-59388
I think I fixed the problem. I booted it up and did a disc check. It found and replaced to files. It works now. I hope. Who knows....
https://linustechtips.com/topic/5126-need-help/#findComment-59389
Corrupted windows by sounds of it. Wierd tho wouldnt have got that from description well done on fixing man :) back up the data while u can could be a faulty hard drive
https://linustechtips.com/topic/5126-need-help/#findComment-59514
Thx:) Ye I am backing it up to my external drive now:)
https://linustechtips.com/topic/5126-need-help/#findComment-59520
Actually never mind it just died AGAIN!!!!!!!!!!!! AAAHHHHHHHHHHHHHHHH! I really need it to work because if it doesnt then my parents are going to have to use mine! I will have to work on it some more.
https://linustechtips.com/topic/5126-need-help/#findComment-59828
OK there is something I would like to add: When I boot it up it says "resuming windows" and then the monitor goes to sleep. I not sure if that helps....
https://linustechtips.com/topic/5126-need-help/#findComment-59831
If it is saying resuming windows then it is going into some kind of power saving state, ie standby or hibernate. Go into power options in control panel and use the high performance profile. If that works then just set the power profile back to normal, open command prompt as an administrator and type "powercfg -h off" without the quotes which will permanently disable hibernate. It may be that the computer does not like some of the power saving features included with Windows 7. Let me know how it goes!
FX-8350          ASUS Crosshair V         MSi R9 290X Gaming 4G
https://linustechtips.com/topic/5126-need-help/#findComment-59835
If you can, go into safe mode and do what he advises^^
If you can aswell... can you install windows on another harddrive and try booting from that on the computer.
Intel Core i7-4790k | ASUS 4GB GTX 970 | 32GB (4X8GB) DDR3 Corsair Dominator Platinum
ASUS MAXIMUS VII HERO | 256GB Samsung 840 Pro + WD 2TB Storage | Corsair Hydro H100i | Windows 8.1 64bit
https://linustechtips.com/topic/5126-need-help/#findComment-59841
Run Linux off of a USB, get important documents/files/whatever of off the windows partition, wipe the drive and do a reinstall.
That's what I would do, assuming the hardware is fine. Does it beep in any particular order/manner? You may want to look that up in your mobo manual.
https://linustechtips.com/topic/5126-need-help/#findComment-59846
I set it to "High performance" mode so far so good,but we will see:) Thx for the help.
https://linustechtips.com/topic/5126-need-help/#findComment-59865
Umm I can but I dont want to try that just yet:)
https://linustechtips.com/topic/5126-need-help/#findComment-59866
Try a fresh install of windows ......!
PC 1: CPU: i5 12600k     GPU: RTX 4080     MOTHERBOARD: Asus B650M-A D4       RAM: 16x4 DDR4 3200       POWERSUPPLY: EVGA 650 G6
SSD: WD Black gen 4 x2 + Crucial MX 500 x2
KEYBOARD: Keychron K4    MOUSE: Logitech G502 SE Hero   MOUSE PAD: Goliathus control XL   MONITOR: Alienware AW3423DW + LG 25UM58 + Dell 24"  Speakers: Edifier R1280T + SVS PB1000
Laptop: M1 MacBook Pro 16
https://linustechtips.com/topic/5126-need-help/#findComment-59869
