Just put the GPU into the PCIE slot, plug in its power connectors and take your video cables out of the onboard adapter and plug it into the GPU.
Marry Christmas! :D
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
https://linustechtips.com/topic/512006-help-with-installing-gpu/#findComment-6822634
I built my pc 3 weeks ago and its running off my i5 4690k and its inbuilt gpu. I just got an r9 380x. I was wondering how I disable the on-board gpu (intel hd) and how to install the gpu. I just need an explanation on what order I do these things in and how. Thanks
Put the GPU into a PIC Express 16x slot. Plug your monitor in that. The Intel GPU will not function automatically since you put in a GPU.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/512006-help-with-installing-gpu/#findComment-6822645
Ok because I've been using the pc with the inbuilt gpu (inbuilt in the cpu) so I dont need to disable it after plugging in the gpu? I just plug and play?
https://linustechtips.com/topic/512006-help-with-installing-gpu/#findComment-6822668
Yep, plug and play. It's better to have the integrated graphics enabled so that you can take advantage of features like quicksync. It helps if you are a broadcaster.
My native language is C++
https://linustechtips.com/topic/512006-help-with-installing-gpu/#findComment-6822709
Yes. That is how it works Merry Christmas!
https://linustechtips.com/topic/512006-help-with-installing-gpu/#findComment-6822715
Marry Christmas! :D
Thanks, Have a merry christmas
https://linustechtips.com/topic/512006-help-with-installing-gpu/#findComment-6822734
