Next year I plan on building a gaming pc with an i5 6600 non k and overclocking it with the bios updates
Should I get an air or water cooler? I'd like to baseclock overclock the chip to 4-4.5 ghz with reasonable voltage and maximum temperatures being around 75-80c
Please respond with your cooler suggestions
Thank You
https://linustechtips.com/topic/511311-recommended-cooler-for-overclocking/
no guarantee you can even get to 4GHz by BCLK
what cooler you get depends on your budget and if you prefer the loos of air or water cooling better
Thank You
The overclocking with bios updates uses multiplier, not BCLK.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
Budget and location?
My budget is $1200-1300 including all peripherals and I live in the US
I prefer water cooling but I can live with an air cooler also
Overclocking on skylake locked chips is done with baseclock and not multiplier because the multiplier is locked on locked chips
he is using a locked chip and u can use bclk with them
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
I thought ASRock's overclocking allowed you to change multiplier. Otherwise, can't (almost) all boards change BCLK regardless of CPU?
Main Gaming Rig:
Secondary PC:
