Help with connections
Solved by Kobathor,
should i just get this one instead it only needs a 8 pin http://www.amazon.com/EVGA-Installed-Backplate-Graphics-04G-P4-3967-KR/dp/B012NOWERC/ref=sr_1_1?s=pc&ie=UTF8&qid=1450577405&sr=1-1&keywords=gtx+960+4gb
Sure. And don't worry, you won't see a performance difference VS the G1 Gaming, it will be around the same.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases6 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
