So I bought a cooler master hyper 212 Evo and I have an LGA 1151 socket, which it didn't say it supported on the box, but people on this forum said that it would be fine. Everything was going well until I tried to fit the mounting bracket on. Is there something I'm doing wrong or does anyone have any tips? Or does it just not work with a 1151 socket?
https://linustechtips.com/topic/508696-cpu-cooler/
I am not sure first hand but you might need new mounting brackets for that new layout,which you can get from CM
If that is this is the case.
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/508696-cpu-cooler/#findComment-6785800
It does support socket lga 1151, just make sure you are using the correct mounting hardwqre, designed for sockets lga 115X
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/508696-cpu-cooler/#findComment-6786030
