how to power my gpu?
By
ozi00
in Graphics Cards
in Graphics Cards
Solved by Sharp_3yE,
YES, use that 8 pin you already have. You have a 750 watt psu which is plenty to power the 980 ti. You have a Semi-Modular psu. That means only some of your cables interchangeable. The others are directly into the psu. Some psu's are fully modular (dont have the bunch of cables, only cables you plug in yourself) and some are not modular at all (only have cables that are directly into the psu).
Featured Topics
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
2
7
2
Shane Martin ·
Posted in Displays2 -
5
INotPablo ·
Posted in CPUs, Motherboards, and Memory2 -
PatRed ·
Posted in New Builds and Planning8
