SMART reliability
By
don_svetlio
in Storage Devices
in Storage Devices
Solved by Captain_WD,
~snip~
You should be fine. The S.M.A.R.T. status is an attribute of the drive's firmware and shouldn't depend on drivers. If the drive passed the extended test and the chkdsk command you should be safe.
Captain_WD.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
