IRQL not less or equal BSOD
Guest
So I built this computer over a month ago and I am getting BSOD. The name of it is IRQL not less or equal.
My specs are as follows:
i5 6600K @4.5ghz
980 Ti
2x8GB Hyper X Fury DDR4
Windows 10 Pro 64bit
With this BSOD I hear it can either be a driver issue or memory issue. I have not used memtest86 yet to test my ram. The odd part of this BSOD is it only happens in Fallout 4 and nothing else. It was not happening before, so I suspect that it could be the latest windows 10 update. So I believe it must be drivers.
Do you guys have any idea?
do a memtest
I had this issue and it was a memory issue
do a memtest
If it is the memory would I have to return it?
Most likely yes
CPU: Intel Xeon E3-1231v3 XX Motherboard: ASRock Fatal1ty H97 Killer XX RAM: G.Skill Ripjaws X Series 16GB (4 x 4GB) DDR3-1600 Memory XX GPU: Asus GeForce GTX 780 3GB DirectCU II XX Case: Phanteks Evolve ATX XX Storage: Kingston SSDNow V300 120GB SSD ; Western Digital Caviar Blue 1TB HDD; Western Digital Caviar Blue 3TB HDD XX PSU: Thermaltake SMART 550W 80+ Bronze
You would need to RMA it
Kingston is great for this
i'd do a cmos reset and try it out.
then I'd try 1 stick in the farthest slot from the cpu. then I would try the other stick in that same slot. then switch each in turn to the other slot, again, switching 1 stick at a time.
Yeah this is exactly what I would do. Further away the RAM stick; the higher the latency = somewhat more stability.
blackshades on
do a memtest
Most likely yes
Ran memtest, no errors
