Seems decent except tat psu.
PCPP link possible?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735727
Change the PSU to a XFX TS 550W.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735729
Looks pretty good except for the PSU, which is a bit underpowered. Maybe get something in the 550-600W range?
The Cheap SFF Wonder -- Turning a Core 2 Duo SFF machine into a useful member of computer society!
i5 3570 -- AS.Rock Z77 Pro3 -- 12GB DDR3 -- R9 380X -- 840Evo 500GB/1TB HDD
I speak the honest truth with a bit of snark mixed in. I'm sorry if it doesn't line up with your beliefs.
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735764
@kameshss sry i didn'd made it in the PCPP
temme ur budget.
And I'll see if I can make a better build in that budget.
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735766
Because the XFX TS 550w is the only PSU that exists on the market, right?
Because it's the cheapest, quality unit in 90% of cases.
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735785
It's a quality OEM unit from Seasonic if i recall correctly.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735786
In 90% of cases? So you know every price of every single PSU in every single country right now and you also know in which country OP lives without even asking him? That's skill...
I'm not saying it's a bad PSU, but I critique Morgan's recommendation. It's very biased to only recommend one product.
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735807
Look into buying this one!
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  (£155.00 @ Amazon UK)
Motherboard: Gigabyte GA-B150M-D3H Micro ATX LGA1151 Motherboard  (£59.99 @ Aria PC)
Video Card: MSI Radeon R9 390 8GB Video Card  (£264.97 @ Aria PC)
Case: NZXT S340 (Black) ATX Mid Tower Case  (£56.99 @ Amazon UK)
Total: £638.89
Generated by PCPartPicker 2015-12-13 15:51 GMT+0000
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735811
Total: £638.89
ok thanks
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735823
ok thanks
Sorry it's in british pounds. my mistake.
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735830
ok thanks
Close to your money budget. In euro
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  (€235.87 @ Mindfactory)
Motherboard: Gigabyte GA-B150M-D3H Micro ATX LGA1151 Motherboard  (€86.80 @ Mindfactory)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€49.90 @ Amazon Deutschland)
Video Card: MSI Radeon R9 380 2GB Video Card  (€193.44 @ Amazon Deutschland)
Case: NZXT S340 (Black) ATX Mid Tower Case  (€83.36 @ Mindfactory)
Total: €649.37
Generated by PCPartPicker 2015-12-13 16:54 CET+0100
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735835
Well, there's nothing wrong with recommending that unit overall tbh. But i see your reasoning, i hate the fanboyism for the 212 EVO cooler, which has been recommended left, right & center for so long on this forum for so long.
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735855
I prefer modular but it's good too @Morgan MLGman
Here's a reasoning. Logic is what I use in my life as a guide, you clearly don't.
He's got a budget build, obviously, it's better to spend as much as you can into the GPU+CPU and get as cheap/good PSU as you can.
I've put hundreds of builds on this forum for people from multiple countries and multiple sites and I'm yet to see XFX TS 550W to be too expensive to be not worth getting.
I've seen it not available, but not overpriced. All XFX PSUs are guaranteed quality cause it's Seasonic OEM.
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6735928
I had a 7 hour discussion about the art of logic. You're using the kind of logic I dislike. But I'm not here to talk about that.
It doesn't matter what kind of build he has, about which component we talk or how many builds you've put together, but just to say "Use this" or "Use that" without an explenation or at least the consideration of a different product is a bad recommendation. You're writing it like the XFX PSU is the only good one on this market.
That's how I think. I'm not saying this to make me look better, but because I care for the people on this forum that need help. I'm here to help those people and if I see a bad recommendation I'll point it out. I do that also to make your recommendation better. It's just a critique that you can accept or not.
Yes, the same happens with a lot of different products like the 212 Evo you mentioned, but also in the form of hate. The Corsair CX PSUs are a good example or the GTX 960. Some people just hate them for whatever reason, even tho they can have their advantages.
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6737504
While I do understand your point, I don't think it really matters to be frank. Here's why it's not good: Some people just come here knowing nothing to ask for help, they don't need an explanation cause sometimes they just wouldn't even understand it, some people just don't care, they want to know what's best, I recommended the XFX TS 550W cause it's cheap, quality and usually in stock in a majority of countries, one of the best units to put in a budget build like OP's, I already recommended a particular unit fit for his particular case to make things faster, as I just know this stuff.
I'm not getting paid for helping people out here, I just enjoy doing so, at first I recommended things your way, with an explanation of why etc., but it just takes significantly more time. That's just a way to make things faster and simpler.
As for the second part, people don't 'hate' the GTX 960, it's just not worth the money and not worth getting considering its place on the market, it's an extremely bad card as far as pricing goes. No reason to recommend it, honestly.
By the way, "You're using the kind of logic I dislike." doesn't disliking something contradicts with logic? I mean it's a subjective matter, as somebody else could just as well 'like' it, that makes it not objective, and that's what logic is based on, at least in my understanding  ( ͡° ͜ʖ ͡°) I'm messing with you, don't answer that, haha
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6737758
You said it takes more time to explain why you recommend a specific product, but you take the time to explain it to me, while I never questioned your choice, but much more the way you recommended it to OP.
That is the kind of logic I dislike. Not liking something is entirely in the rules of logic, cause that is what we humans do. It is logical that humans think subjectively, because our opinions are based on our experience. To know that, lets me see the real logic as a art and not the logic I dislike. Answering that was logical to me, cause you seem like a person that is able to understand that.  ;)
In some scenarios it makes sense to prefer a GTX 960, but I will not get into an argument about the that for now.
https://linustechtips.com/topic/504604-my-first-build-again/#findComment-6737909
