So my sister needs more ram in an all in one day pc as that is what is bottlenecking her system.
I need to get the best deal I can for about $35 give or take a little (USD).
The system she uses is an apu so it would be awesome to get faster ram like as fast as possible without sacrificing performance also 1x8 stick or 2x8 is the only real option as any set of 4gb sticks would result in a waste.
So short and sweet:
Need at least 8gb
Of fast (like faster than 2133)
Ddr3l sdram (like laptops)
Thanks guys for the help!
Merry Christmas.
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/
even with the APU which uses RAM for VRAM
most laptops only can run max 1866MHz RAMs
heck laptops only comes with 1600MHz because they are cheap
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717220
So short and sweet:
Need at least 8gb
Merry Christmas.
@dragoon20005 is correct. We need to know the model of the laptop before we even know how much it will support, let alone what speeds it will support. Either way, here is what you asked for: http://pcpartpicker.com/parts/memory/#t=9&sort=d2&page=1&Z=8192001,16384002&s=302133
My (incomplete) memory overclocking guide:
Does memory speed impact gaming performance? Click here to find out!
On 1/2/2017 at 9:32 PM, MageTank said:
Sometimes, we all need a little inspiration.
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717245
I don't know how I can truly tell the fastest speed but I would still like to get like 2133 or so just in case do you have any reccomendations?
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717256
Just tell us the model of the laptop. We can determine that information for you, and tell you which speeds to get without wasting extra cash.
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717269
if you can use CPU-Z ID on the laptop
it will pull out the RAM details
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717273
Here is the model I can't find a lot of info but thanks for the help:
http://www.bestbuy.com/site/hp-21-5-touch-screen-all-in-one-amd-a4-series-4gb-memory-500gb-hard-drive-black/8585117.p?id=1219350933628&skuId=8585117
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717292
Thanks will have to get this info tomorrow but I posted link to model
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717300
gotcha
found it
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=c04454102
yea only supports 1600MHz RAMs
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717327
gotcha
found it
Thanks this will save me a lot of money!
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717345
204 for DDR3 SO-DIMM. Use this list: https://pcpartpicker.com/parts/memory/#t=9&Z=8192001,16384002&sort=a7&page=1
It's 1600mhz DDR3 SO-DIMM memory, listed from the best Price:GB. 1x8GB and 2x8GB sticks. Good luck on your upgrade.
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717365
Thanks for the help!
https://linustechtips.com/topic/503073-need-ddr3l-sdram-help/#findComment-6717389
