Cpu frying
Go to solution Solved by hypnodog,
If you sent 5V through it, it's probably dead.
Hello everyone. A month or so ago i scavenged a old cpu from some place. And i got it because i wanted to create a handwarmer like in greatscot's video on youtube. The cpu is a Intel pentium e2140 clocked at 1.6 gh and 1mb cache. And so i found 2 pins to pump power through and now a few months later im wondering. Did i fry the cpu? it wasn't a lot of power max 500mA at 5V. So could i still use it. I don't have the equipment to test it so o thought i'd ask here.
Thanks for your help already
https://linustechtips.com/topic/502208-cpu-frying/
I'm not entirely sure what you're asking... Or saying...
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705016
I don't think anyone can tell, the best way to make sure is to test it.
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705022
he used a cpu , and connected power to it.
ading power caused it to warm up, which he then used as a hand warmer
Hello everyone. A month or so ago i scavenged a old cpu from some place. And i got it because i wanted to create a handwarmer like in greatcoats video on youtube. The cpu is a Intel pentium e2140 clocked at 1.6 gh and 1mb cache. And so i found 2 pins to pump power through and now a few months later im wondering. Did i fry the cpu? it wasn't a lot of power max 500mA at 5V. So could i still use it. I don't have the equipment to test it so o thought i'd ask here.
possibly, theres no way to check, unless you arcually test it
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705027
Um... In that case... It might be dead.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705066
but that is also the problem i don't mind buying the motherboard and ram to test it but i'm afraid that if it is dead that it wel also take rest of the system
i wouldn't bother, it's not worth it.
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705073
Might, but wouldnt hurt to go to the local computer store, get a board, test, and if it fries the board then return it saying it was faulty. Most stores have return policies of money back no questions asked if returned in 7 days.
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705091
Intel pentium e2140
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705112
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705129
Just why...
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705146
but that is also the problem i don't mind buying the motherboard and ram to test it but i'm afraid that if it is dead that it wel also take rest of the system.
Broken CPU doesn't cause problems to rest of the system. It will just waste your money.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705241
If the CPU is dead, the system would just fail to post. Nothing would be harmed.
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705254
This.
But for science, you should put increasing amounts of volts through it......for science.....also, put it on YouTube if the results prove interesting. I vote for 240v @ 2amps.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705318
5v definitely killed it.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6705865
In addition to a hand warmer did you use a pot of oil for a heatsink and fry some fish in it?
https://linustechtips.com/topic/502208-cpu-frying/#findComment-6706874
