I need help.
What is best headphons/headset for 150$
Is audio technica atmh50x is the best one?
That's really subjective. Do you need a mic? Do you need noise isolation or are you OK with an open-back design for a better soundstage at the expense of noise leakage?
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6703982
- no idont like open pack.
-I want it for listen to music and to make my video sound quality more accurate.
-no idont need mic.
:D
Don't forget to quote people so they get a notification that they replied!
Are you going to be travelling outside a lot with these on? If so then the M40X/M50X (M40x are slightly cheaper and have a more neutral sound rather than the bassier M50s) are a good choice. If not, then the NVX XPT100 are a good choice.
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6704037
No it's server problems,sorry k
yeah, but here's the thing, the spam of 3-4 post always happens by a newbie and never a person who has more than 100 posts, i seriously believe you guys press post 4 times by accident or something.
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6704109
Yeh mate you can buy a phenomenal pair of surround sound gaming and speech headphones for £20.
If you are using them for a quality audio playback , , studiowise , you will need a better pair.
I.e Audio Technica have a large range of studio quality headphones , for 100 dollars you will find something necessary.
I wouldnt spend 100 dollars on studio headphones for gaming , totally unecessary!
Like buying a Lamborghini Countach to go to the Launderette in!
lol
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6704118
lol
What?.... You make like no sense whatsoever anyhow I would say the M40x is probably your best bet then.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6705337
Lol......it makes sense!   The expense for quality playback sound is in your soundcard , not your headphones!
eb6.jpg?1307463786
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6714938
Well as a primary consideration anyway!
You should read up on stuff because a sound card doesn't make your sound instantly good.
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6715516
Hi there,
I wanna buy a headset with the following features.
- separate chat / game volume control
- steel or mixed plastic/steel, durable headband adjustment piece
- noise cancelling mic
- adjustable mic feedback volume
- possibly wireless or with at least 9 feet long cable.
price range $100 - $200
Any advice?
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6719019
Hi there,
Any advice?
Please make your own thread so that people can help you there.
Ha ha me or you?   Not a troll.
If not a troll, then you need to do some research.
MSI Z97M Gaming | i7-4790k | NZXT Kraken X61 | 16GB Kingston Savage DDR3 2400
EVGA GTX1080 Ti FTW3 | EVGA G2 750 | Phanteks Enthoo Evolv | 1TB 850 Evo | 2TB 860 Evo | 22TB DS918+
Scarlett 2i2 | WooAudio WA7 Fireflies | Fostex TR-X00 | Beyer DT990 | MrSpeaker Alpha Dog | V-Moda M-100 | JBL LSR305 MK2
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6720132
If your not a troll, then you are the other option stated in the meme.
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6722250
Who sold you crack?
AMD VS Nvidia = A lost mail man that will do whatever it takes to give you your mail... despite being a few days late... and never realizing that the house that the mail is for was pretty much the first house he started from VS A well dressed, well groomed, well cleaned, and cologned-up donger that just wiggles itself and is the type of guy that makes after-parties a nightmare. Basically its: An idiot that tries VS a jerk that ruins every after-party. Pick your poison.
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6722777
-no I am just going to use them inside.
-I found a deal for (new) m50x for 99$.is these good deal.
Nope. If I were you, I'd go for the NVX XPT100 or even something like the MDR V6 or 7506.
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6722787
Well aye , if you buy a crap soundcard , mine is external and proper studio quality , a fairly content pair of studio headphones will bring you a very nice sound for not too high a price..
"should read up!"
"Ahem!"
If you have a basic or lowriding internal soundcard your headphones , the more suped up they are will give you a better signal.....
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6770665
Hi there,
Any advice?
Dude get these Element elite 7:1 surround ones i got with pull down microphone , volume hand controller down the cable , easy 4 m cable...check em out!
http://www.elementgaming.com/headsets/xenon-600/
These is them , but i got mine for £20 quid...can,t remember where but i can check if you haven,t already bought them.
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6770680
"should read up!"
"Ahem!"
Whatever you do don't listen to this kid and english is bad to boot.
P.S. This thread is really old and those Element 7.1 Headsets you linked are garbage.
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6771349
Studio quality + $30 "gaming" headset definitely to together... I mean, look at the people who buy Razer headsets or Siberias and think they are top notch quality. Add a $200 sound card or $500+ dac/amp and those Razer headsets REALLY come to life!!!
https://linustechtips.com/topic/502125-pro-audio-headset/#findComment-6772291
