Best display for $100?
Tmt97
My TV isn't compatible with my new graphics card for some reason. I need something made in the last decade to replace it with, in a budget of $100. Doesn't have to be the best thing in the world, it just needs to run. If possible, I'd prefer something that I can eventually buy more of, to make a multi-monitor setup.
Don't do drugs. Do hugs!
Size? Resolution?
Size? Resolution?
Well, best I can get I guess. I am kinda a noob to monitors/TVs, but I figured I couldn't be too picky with a budget of $100. I do like big things, so yea... Did I mention, I am REALLY a noob when it comes to this topic lol.
TheGrim123321
CPU: I3-4170Cooler: Hyper TX3Mobo:Biostar B85MGMemory: G.Skill Ripjaw 2x4GBStorage: Barracuda 500GBGPU: Zotac GTX660Case: Fractal 1100PSU: Evga 500WMonitors: FHX2153L 21.5"│V193WEJb 19"Keyboard/Mouse: CMStorm DevastorAudio: MonoPrice 8323Microphone: BlueYeti BlackoutOS: MSX(Win10) Quote me or @TheGrim123321 to get my attention.
try used
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
Pretty low price point for a decent sized TV, i'd just stick to a monitor until you have 150-200 and pick up a 32 or 40 incher
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
Also, is there any way of knowing before I buy it, if the monitor is compatible with a radeon 7950?
If it has an HDMI port and so does your monitor. Will work
TheGrim123321
what outputs does your 7950 have? I'd assume hdmi and displayport, then just match them to your monitor that you want
Nope. My current display has an HDMI port, and so does the card. They don't work together no matter what I do. The same desktop works fine with said display if I put another card in.
The 7950 has two displayports, one hdmi, and two DVI. I matched them to the display just fine but it didn't work. If I connect the same computer to the same display but with a different card, it works fine. If I connect the same computer with the same card to a different display, again it works fine. But the card just doesn't work with the display even with compatible IO. It might just be because its old, and the card is new, but I wanted to be sure that I'm going to be able to interface with this new monitor if I buy it.
http://www.amazon.com/Acer-G246HL-Abd-24-Inch-LED-Lit/dp/B0098Y77OG/ref=sr_1_3?s=pc&ie=UTF8&qid=1427672514&sr=1-3&keywords=IPS
I've got this one and it's alright, plastic is a little cheap, but it's bright and the colours are pretty decent, or there's the 23 inch version for $10 less, or 21.5 inch for $20 less than that ($90)
Only has VGA and DVI inputs, though you can easily get adapters if needed to go from dvi to hdmi or vice versa.
